New interface
Reports (Research report)
Convergence Analysis of a Projection Semi-Implicit Coupling Scheme for Fluid-Structure Interaction Problems
Matteo Astorino 1 Céline Grandmont 1, *
* Corresponding author
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In this paper, we provide a convergence analysis of a projection semi-implicit scheme for the simulation of fluid-structure systems involving an incompressible viscous fluid. The error analysis is performed on a fully discretized linear coupled problem: a finite element approximation and a semi-implicit time-stepping strategy are respectively used for space and time discretization. The fluid is described by the Stokes equations, the structure by the classical linear elastodynamics equations and all changes of geometry are neglected. We derive an error estimate in finite time and we prove that the time discretization error for the coupling scheme is at least $\sqrt{\delta t}$. Finally, some numerical experiments that confirm the theoretical analysis are presented.
Document type :
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/inria-00406493
Contributor : Matteo Astorino Connect in order to contact the contributor
Submitted on : Friday, December 3, 2010 - 1:12:03 PM
Last modification on : Thursday, October 27, 2022 - 4:02:56 AM
Long-term archiving on: : Saturday, December 3, 2016 - 2:20:17 AM
File
astorino-grandmont.pdf
Identifiers
  • HAL Id : inria-00406493, version 3
Citation
Matteo Astorino, Céline Grandmont. Convergence Analysis of a Projection Semi-Implicit Coupling Scheme for Fluid-Structure Interaction Problems. [Research Report] RR-6996, INRIA. 2009. ⟨inria-00406493v3⟩
Share
Metrics
Record views
169
Files downloads
340
