Surface reconstruction by voronoi ltering, Discrete Comput . Geom, vol.22, p.481504, 1999. ,
Voronoi-based variational reconstruction of unoriented point sets, Proc. Eurographics Symp. Geom. Proc, p.3948, 2007. ,
Dening point-set surfaces, ACM Trans. Graph, vol.23, issue.3, 2004. ,
Cohen-Or, 4-points congruent sets for robust pairwise surface registration, ACM Trans. Graph, vol.27, issue.3, 2008. ,
Computation of surface geometry and segmentation using covariance techniques, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.11, 1994. ,
DOI : 10.1109/34.334391
Geometric Inference for Measures based on Distance Functions, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00383685
Analysis of scalar elds over point cloud data, Proc. ACM/SIAM Symp. Disc. Algo, p.10211030, 2009. ,
Measurement of protein surface shape by solid angles, Journal of Molecular Graphics, vol.4, issue.1 ,
DOI : 10.1016/0263-7855(86)80086-8
Estimating dierential quantities using polynomial tting of osculating jets, Comp. Aided Geom. D, p.121146, 2005. ,
Shape segmentation and matching from noisy point clouds, Proc. Eurographics Symp. Point-based Graph, p.193199, 2004. ,
Shape Dimension and Approximation from Samples, Discrete and Computational Geometry, vol.29, issue.3, p.419434, 2003. ,
DOI : 10.1007/s00454-002-2838-9
Spline-based feature curves from point-sampled geometry, The Visual Computer, vol.31, issue.7, p.449462, 2008. ,
DOI : 10.1007/s00371-008-0223-2
Robust moving least-squares tting with sharp features, ACM Trans. Graph, vol.24, issue.3, p.544552, 2005. ,
Shape segmentation using local slippage analysis, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, p.214223, 2004. ,
DOI : 10.1145/1057432.1057461
Shape-based recognition of 3D point clouds in urban environments, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459471
Curvaturedriven modeling and rendering of point-based surfaces ,
Combinatorial manifold mesh reconstruction and optimization from unorganized points with arbitrary topology, Computer-Aided Design, vol.34, issue.2, p.149165, 2002. ,
DOI : 10.1016/S0010-4485(01)00079-3
Patch-graph reconstruction for piecewise smooth surfaces, Proc. of Vis., Mod., Vis, 2008. ,
Extracting lines of curvature from noisy point clouds, Special Issue of the Elsevier Computer-Aided Design journal on Point-Based Computational Techniques, p.41, 2009. ,
Data-dependent MLS for faithful surface approximation, Proc. Eurographics Symp, p.5967, 2007. ,
Anisotropic smoothing of point sets, Computer Aided Geometric Design, vol.22, issue.7 ,
DOI : 10.1016/j.cagd.2005.06.010
ANN: A library for approximate nearest neighbor searching ,
Robust Voronoi-based curvature and feature estimation, 2009 SIAM/ACM Joint Conference on Geometric and Physical Modeling on, SPM '09, p.112, 2009. ,
DOI : 10.1145/1629255.1629257
A comparison of Gaussian and mean curvature estimation methods on triangular meshes of range image data, Computer Vision and Image Understanding, vol.107, issue.3, p.139159, 2007. ,
DOI : 10.1016/j.cviu.2006.09.007
Feature Preserving Point Set Surfaces based on Non-Linear Kernel Regression, Computer Graphics Forum, vol.16, issue.2, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01388.x
URL : https://hal.archives-ouvertes.fr/inria-00354969
Multi-scale Feature Extraction on Point-Sampled Surfaces, Computer Graphics Forum, vol.30, issue.2, 2003. ,
DOI : 10.1111/1467-8659.00675
Discovering structural regularity in 3d geometry, ACM Trans. Graph, vol.27, issue.3, 2008. ,
Integral invariants for robust geometry processing, Computer Aided Geometric Design, vol.26, issue.1, p.3760, 2009. ,
DOI : 10.1016/j.cagd.2008.01.002
A survey on Mesh Segmentation Techniques, Computer Graphics Forum, vol.26, issue.5, p.15391556, 2008. ,
DOI : 10.1111/j.1467-8659.2007.01103.x
Matrix perturbation theory, Computer Science and Scientic Computing, 1990. ,
Direct computing of surface curvatures for point-set surfaces, Proc. Eurographics Symp. Point-based Graph, 2007. ,
