HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Minimum information requirements : neither bandits in the Attic nor bats in the belfry
David James Sherman 1, 2, *
* Corresponding author
1 MAGNOME - Models and Algorithms for the Genome
Inria Bordeaux - Sud-Ouest, UB - Université de Bordeaux, CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : In respose to de Marco and colleagues 'Minimum Information for Protein Functional Evaluation,' I observe that they run the risk of imposing a Procrustean solution to the problem of rigorously reporting experimental results involving recombinant proteins. While they rightly identify a need for experimental reporting standards defined by their scientific community, they wrongly assign this role to 'Minimum information' guidelines. In my response I clarify the role and development processes of minimum information standards, and relate a similar experience that we had in the ProteomeBinders Consortium, that led to a distinction between minimum information guidelines for describing a binder and its efficiency as a molecular tool, and the need to define community standards for experimental binder assessment.
Complete list of metadata
https://hal.inria.fr/inria-00407505
Contributor : David James Sherman Connect in order to contact the contributor
Submitted on : Friday, July 24, 2009 - 11:08:25 PM
Last modification on : Monday, December 20, 2021 - 4:50:15 PM
Links full text
Identifiers
Citation
David James Sherman. Minimum information requirements : neither bandits in the Attic nor bats in the belfry. New Biotechnology, Elsevier, 2009, 25 (4), pp.173-4. ⟨10.1016/j.nbt.2008.12.002⟩. ⟨inria-00407505⟩
Share
Metrics
Record views
48
