Sparse and Redundant Modeling of Image Content Using an Image-Signature-Dictionary, SIAM Journal on Imaging Sciences, vol.1, issue.3, pp.228-247, 2008. ,
DOI : 10.1137/07070156X
<tex>$rm K$</tex>-SVD: An Algorithm for Designing Overcomplete Dictionaries for Sparse Representation, IEEE Transactions on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
DOI : 10.1109/TSP.2006.881199
Consistency of the group Lasso and multiple kernel learning, Journal of Machine Learning Research, vol.9, pp.1179-1224, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00164735
Convex sparse matrix factorizations, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00345747
Nonlinear Programming, Athena Scientific Belmont, 1999. ,
Simultaneous analysis of Lasso and Dantzig selector, The Annals of Statistics, vol.37, issue.4, pp.1705-1732, 2009. ,
DOI : 10.1214/08-AOS620
URL : https://hal.archives-ouvertes.fr/hal-00401585
Optimization Problems with Perturbations: A Guided Tour, SIAM Review, vol.40, issue.2, pp.202-227, 1998. ,
DOI : 10.1137/S0036144596302644
URL : https://hal.archives-ouvertes.fr/inria-00073819
Perturbation Analysis of Optimization Problems, 2000. ,
DOI : 10.1007/978-1-4612-1394-9
Convex Analysis and Nonlinear Optimization: Theory and Examples, 2006. ,
Online algorithms and stochastic approximations, Online Learning and Neural Networks, 1998. ,
The trade-offs of large scale learning, Advances in Neural Information Processing Systems, pp.161-168, 2008. ,
Differentiable sparse coding, Advances in Neural Information Processing Systems, pp.113-120, 2009. ,
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1999. ,
DOI : 10.1137/S1064827596304010
Genomic and transcriptional aberrations linked to breast cancer pathophysiologies, Cancer Cell, vol.10, issue.6, pp.529-541, 2006. ,
DOI : 10.1016/j.ccr.2006.10.009
URL : http://doi.org/10.1016/j.ccr.2006.10.009
Sparse solutions to linear inverse problems with multiple measurement vectors, IEEE Transactions on Signal Processing, vol.53, issue.7, pp.2477-2488, 2005. ,
DOI : 10.1109/TSP.2005.849172
The theory of max-min, and its application to weapons allocation problems. ¨ Okonometrie und Unternehmensforschung, 1967. ,
A Direct Formulation for Sparse PCA Using Semidefinite Programming, SIAM Review, vol.49, issue.3, pp.434-448, 2007. ,
DOI : 10.1137/050645506
Optimal solutions for sparse principal component analysis, Journal of Machine Learning Research, vol.9, pp.1269-1294, 2008. ,
Efficient projections onto the ? 1 -ball for learning in high dimensions, Proceedings of the International Conference on Machine Learning (ICML), 2008. ,
Least angle regression, Annals of Statistics, vol.32, issue.2, pp.407-499, 2004. ,
Image Denoising Via Sparse and Redundant Representations Over Learned Dictionaries, IEEE Transactions on Image Processing, vol.15, issue.12, pp.3736-3745, 2006. ,
DOI : 10.1109/TIP.2006.881969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6477
Frame based signal compression using method of optimal directions (MOD), ISCAS'99. Proceedings of the 1999 IEEE International Symposium on Circuits and Systems VLSI (Cat. No.99CH36349), 1999. ,
DOI : 10.1109/ISCAS.1999.779928
Nonnegative Matrix Factorization with the Itakura-Saito Divergence: With Application to Music Analysis, Neural Computation, vol.14, issue.3, pp.793-830, 2009. ,
DOI : 10.1016/j.sigpro.2007.01.024
Quasi-martingales. Transactions of the, pp.359-388, 1965. ,
DOI : 10.1090/s0002-9947-1965-0192542-5
Pathwise coordinate optimization, The Annals of Applied Statistics, vol.1, issue.2, pp.302-332, 2007. ,
DOI : 10.1214/07-AOAS131
Penalized regressions: The bridge versus the Lasso, Journal of Computational and Graphical Statistics, vol.7, pp.397-416, 1998. ,
Recovery of Exact Sparse Representations in the Presence of Bounded Noise, IEEE Transactions on Information Theory, vol.51, issue.10, pp.3601-3608, 2005. ,
DOI : 10.1109/TIT.2005.855614
From few to many: illumination cone models for face recognition under variable lighting and pose, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.6, pp.643-660, 2001. ,
DOI : 10.1109/34.927464
Matrix computations, 1996. ,
Shift-invariant sparse coding for audio classification, Proceedings of the Twenty-third Conference on Uncertainty in Artificial Intelligence (UAI), 2007. ,
MéthodesMéthodesà Noyaux pour la Détection, 2008. ,
Catching change-points with Lasso, Advances in Neural Information Processing Systems, pp.161-168, 2008. ,
RELATIONS BETWEEN TWO SETS OF VARIATES, Biometrika, vol.28, issue.3-4, pp.321-377, 1936. ,
DOI : 10.1093/biomet/28.3-4.321
Non-negative sparse coding, Proceedings of the 12th IEEE Workshop on Neural Networks for Signal Processing, 2002. ,
DOI : 10.1109/NNSP.2002.1030067
URL : http://arxiv.org/abs/cs/0202009
Non-negative matrix factorization with sparseness constraints, Journal of Machine Learning Research, vol.5, pp.1457-1469, 2004. ,
Group lasso with overlap and graph lasso, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553431
Structured variable selection with sparsityinducing norms, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00377732
Structured sparse principal component analysis, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00414158
A Modified Principal Component Technique Based on the LASSO, Journal of Computational and Graphical Statistics, vol.12, issue.3, pp.531-547, 2003. ,
DOI : 10.1198/1061860032148
Fast inference in sparse coding algorithms with applications to object recognition, 2008. ,
Matrix Factorization Techniques for Recommender Systems, Computer, vol.42, issue.8, pp.30-37, 2009. ,
DOI : 10.1109/MC.2009.263
Stochastic Approximation and Recursive Algorithms and Applications, 2003. ,
Algorithms for non-negative matrix factorization, Advances in Neural Information Processing Systems, pp.556-562, 2001. ,
Efficient sparse coding algorithms, Advances in Neural Information Processing Systems, pp.801-808, 2007. ,
Acquiring linear subspaces for face recognition under variable lighting, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.5, pp.684-698, 2005. ,
Learning Overcomplete Representations, Neural Computation, vol.33, issue.2, pp.337-365, 2000. ,
DOI : 10.1109/18.119725
Projected Gradient Methods for Nonnegative Matrix Factorization, Neural Computation, vol.5, issue.10, pp.2756-2779, 2007. ,
DOI : 10.1007/BF01584660
A linear-time median-finding algorithm for projecting a vector on the simplex of n, Operations Research Letters, vol.8, issue.4, pp.219-222, 1989. ,
DOI : 10.1016/0167-6377(89)90064-3
Matrix Differential Calculus with Applications in Statistics and Econometrics, revised edition, 1999. ,
Discriminative learned dictionaries for local image analysis, 2008 IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
DOI : 10.1109/CVPR.2008.4587652
Sparse Representation for Color Image Restoration, IEEE Transactions on Image Processing, vol.17, issue.1, pp.53-69, 2008. ,
DOI : 10.1109/TIP.2007.911828
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.102.6724
Learning Multiscale Sparse Representations for Image and Video Restoration, Multiscale Modeling & Simulation, vol.7, issue.1, pp.214-241, 2008. ,
DOI : 10.1137/070697653
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.105.6238
Online dictionary learning for sparse coding, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553463
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.184.5417
Supervised dictionary learning, Advances in Neural Information Processing Systems, pp.1033-1040, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00322431
Non-local sparse models for image restoration, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459452
A Wavelet Tour of Signal Processing, Second Edition, 1999. ,
Semi-martingales, 1983. ,
A view of the EM algorithm that justifies incremental, sparse, and other variants. Learning in Graphical Models, pp.355-368, 1998. ,
Gradient methods for minimizing composite objective function, Center for Operations Research and Econometrics (CORE), 2007. ,
Union support recovery in highdimensional multivariate regression, UC Berkeley Technical Report, vol.761, 2008. ,
Joint covariate selection and joint subspace selection for multiple classification problems, Statistics and Computing, vol.8, issue.68, 2009. ,
DOI : 10.1007/s11222-008-9111-x
Sparse coding with an overcomplete basis set: A strategy employed by V1?, Vision Research, vol.37, issue.23, pp.3311-3325, 1997. ,
DOI : 10.1016/S0042-6989(97)00169-7
A new approach to variable selection in least squares problems, IMA Journal of Numerical Analysis, vol.20, issue.3, pp.389-403, 2000. ,
DOI : 10.1093/imanum/20.3.389
Sparse Modeling of Textures, Journal of Mathematical Imaging and Vision, vol.27, issue.2, pp.17-31, 2009. ,
DOI : 10.1007/s10851-008-0120-3
Image Sequence Denoising via Sparse and Redundant Representations, IEEE Transactions on Image Processing, vol.18, issue.1, pp.27-36, 2009. ,
DOI : 10.1109/TIP.2008.2008065
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.159.8253
Self-taught learning, Proceedings of the 24th international conference on Machine learning, ICML '07, 2007. ,
DOI : 10.1145/1273496.1273592
The Group-Lasso for generalized linear models, Proceedings of the 25th international conference on Machine learning, ICML '08, 2008. ,
DOI : 10.1145/1390156.1390263
Stochastic convex optimization, 22nd Annual Conference on Learning Theory (COLT), 2009. ,
Learning and Example Selection for Object and Pattern Recognition, 1996. ,
Regression shrinkage and selection via the Lasso, Journal of the Royal Statistical Society. Series B, vol.58, issue.1, pp.267-288, 1996. ,
Spatial smoothing and hot spot detection for CGH data using the fused lasso, Biostatistics, vol.9, issue.1, pp.18-29, 2008. ,
DOI : 10.1093/biostatistics/kxm013
Sparsity and smoothness via the fused lasso, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.99, issue.1, pp.91-108, 2005. ,
DOI : 10.1016/S0140-6736(02)07746-2
Algorithms for simultaneous sparse approximation. part ii: Convex relaxation. Signal Processing, Special Issue " Sparse Approximations in Signal and Image Processing, pp.589-602, 2006. ,
DOI : 10.1016/j.sigpro.2005.05.030
Algorithms for simultaneous sparse approximation . part i: Greedy pursuit. Signal Processing, Special Issue " Sparse Approximations in Signal and Image Processing, pp.572-588, 2006. ,
Simultaneous Variable Selection, Technometrics, vol.47, issue.3, pp.349-363, 2005. ,
DOI : 10.1198/004017005000000139
Asymptotic Statistics, 1998. ,
A penalized matrix decomposition, with applications to sparse principal components and canonical correlation analysis, Biostatistics, vol.10, issue.3, pp.515-534, 2009. ,
DOI : 10.1093/biostatistics/kxp008
Coordinate descent algorithms for lasso penalized regression, The Annals of Applied Statistics, vol.2, issue.1, pp.224-244, 2008. ,
DOI : 10.1214/07-AOAS147SUPP
Linear spatial pyramid matching using sparse coding for image classification, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
Nonnegative sparse PCA, Advances in Neural Information Processing Systems, pp.1561-1568, 2007. ,
Variable selection for the multicategory SVM via adaptive sup-norm regularization, Electronic Journal of Statistics, vol.2, issue.0, pp.149-167, 2008. ,
DOI : 10.1214/08-EJS122
Blind Source Separation by Sparse Decomposition in a Signal Dictionary, Neural Computation, vol.1, issue.4, pp.863-882, 2001. ,
Regularization and variable selection via the elastic net, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.5, issue.2, pp.301-320, 2005. ,
DOI : 10.1073/pnas.201162998
Sparse Principal Component Analysis, Journal of Computational and Graphical Statistics, vol.15, issue.2, pp.265-286, 2006. ,
DOI : 10.1198/106186006X113430
