AN ANALYSIS OF HIGHER ORDER BOUNDARY CONDITIONS FOR THE WAVE EQUATION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2005
Thanks to the use of the Cagniard–De Hoop method, we derive an analytic solution in the time domain for the half-space problem associated with the wave equation with Engquist– Majda higher order boundary conditions. This permits us to derive new convergence results when the order of the boundary condition tends to infinity, as well as error estimates. The theory is illustrated by numerical results.
abc.pdf (1007.98 Ko) Télécharger le fichier
inria-00409197 , version 1 (06-08-2009)
Julien Diaz, Patrick Joly. AN ANALYSIS OF HIGHER ORDER BOUNDARY CONDITIONS FOR THE WAVE EQUATION. SIAM Journal on Applied Mathematics, 2005, 65 (5), pp.1547-1575. ⟨10.1137/S0036139903436145⟩. ⟨inria-00409197⟩
131 Consultations
291 Téléchargements
