New interface
Journal articles
Achieving Portable and Efficient Parallel CORBA Objects
Alexandre Denis 1, 2 Christian Pérez 3 Thierry Priol 3
2 RUNTIME - Efficient runtime systems for parallel architectures
INRIA Futurs, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
3 PARIS - Programming distributed parallel systems for large scale numerical simulation
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, ENS Cachan - École normale supérieure - Cachan, Inria Rennes – Bretagne Atlantique
Abstract : With the availability of Computational Grids, new kinds of applications are emerging. They raise the problem of how to program them on such computing systems. In this paper, we advocate a programming model based on a combination of parallel and distributed programming models. Compared to previous approaches, this work aims at bringing SPMD programming into CORBA in a portable way. For example, we want to interconnect two parallel codes by CORBA without modifying either CORBA or the parallel communication API. We show that such an approach does not entail any loss of performance compared to previous approaches that required modification to the CORBA standard. Moreover, using an ORB that is able to exploit high performance networks, we show that portable parallel CORBA objects can efficiently make use of such networks.
Document type :
Journal articles
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00411025
Contributor : Alexandre Denis Connect in order to contact the contributor
Submitted on : Tuesday, August 25, 2009 - 3:43:47 PM
Last modification on : Saturday, June 25, 2022 - 10:31:49 AM
Long-term archiving on: : Tuesday, June 15, 2010 - 8:08:49 PM
DenPerPriCCPE.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Alexandre Denis, Christian Pérez, Thierry Priol. Achieving Portable and Efficient Parallel CORBA Objects. Concurrency and Computation: Practice and Experience, 2003, 15 (10), pp.891-909. ⟨10.1002/cpe.738⟩. ⟨inria-00411025⟩
Share
Metrics
Record views
154
Files downloads
212
