Conference papers
New antenna diversity front-end using code multiplexing
Matthieu Gautier 1 Ioan Burciu 1 Guillaume Villemaud 1
1 SWING - Smart Wireless Networking
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : In this paper, we address the architecture of an antenna diversity receiver. An innovative architecture has been introduced based on code multiplexing, it significantly reduces the power consumption of the front-end. This architecture uses the direct sequence spread spectrum technique in order to multiplex the different antennas contributions through a single IQ demodulator. This paper address the performances of this kind of architecture. Simulation and measurement results show that, in a Gaussian case, the bit error rate does not increase significantly with the multiplexing. IQ imbalance study shows that the new architecture has the same sensitivity to IQ mismatches than the classical stack-up architecture.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00412047
Contributor : Guillaume Villemaud Connect in order to contact the contributor
Submitted on : Friday, November 27, 2009 - 10:34:50 AM
Last modification on : Friday, February 4, 2022 - 3:12:30 AM
Long-term archiving on: : Tuesday, June 15, 2010 - 10:57:53 PM
File
25.pdf
Identifiers
  • HAL Id : inria-00412047, version 1
Collections
Citation
Matthieu Gautier, Ioan Burciu, Guillaume Villemaud. New antenna diversity front-end using code multiplexing. European Conference on Antennas and Propagation, Mar 2009, Berlin, Germany. ⟨inria-00412047⟩
Share
Metrics
Record views
153
Files downloads
143
