Abstract : In this paper, we address the architecture of an antenna diversity receiver and we aim to reduce the complexity of the analog front-end. To this end, an innovative architecture is introduced based on code multiplexing. This architecture uses the direct sequence spread spectrum technique in order to multiplex the different antennas contributions through a single demodulator. Simulation and measurement results show that, in a Gaussian case, the bit error rate does not increase so much with the multiplexing. The complexity evaluation shows that the proposed architecture significantly reduces the power consumption of the front-end.
