Impact of the Physical Layer Modeling on the Accuracy and Scalability of Wireless Network Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIMULATION: Transactions of The Society for Modeling and Simulation International Année : 2009
Guillaume Chelius
  • Fonction : Auteur
  • PersonId : 853112
Jean-Marie Gorce
Recent years have witnessed a tremendous growth of research in the field of wireless systems and networking protocols. Consequently, simulation has appeared as the most convenient approach for the performance evaluation of such systems and several wireless network simulators have been proposed in recent years. However, the complexity of the wireless physical layer (PHY) induces a clear tradeoff between the accuracy and the scalability of simulators. Thereby, the accuracy of the simulation results varies drastically from one simulator to another. In this paper, we focus on this tradeoff and we investigate the impact of the physical layer modeling accuracy on both the computational cost and the confidence in simulations. We first provide a detailed discussion on physical layer issues, including the radio range, link and interference modeling, and we investigate how they have been handled in existing popular simulators. We then introduce a flexible and modular new wireless network simulator, called WSNet. Using this simulator, we analyze the influence of the PHY modeling on the performance and the accuracy of simulations. The results show that the PHY modeling, and in par ticular interference modeling, can have a significant impact on the behavior of the evaluated protocols at the expense of an increased computational overhead. Moreover, we show that the use of realistic propagation models can improve the simulation accuracy without inducing a severe degradation of scalability.
ebenhami_article.pdf (268.17 Ko) Télécharger le fichier
inria-00412150 , version 1 (01-09-2009)
Elyes Ben Hamida, Guillaume Chelius, Jean-Marie Gorce. Impact of the Physical Layer Modeling on the Accuracy and Scalability of Wireless Network Simulation. SIMULATION: Transactions of The Society for Modeling and Simulation International, 2009, 85 (9), pp.574-588. ⟨10.1177/0037549709106633⟩. ⟨inria-00412150⟩
359 Consultations
656 Téléchargements
