Segmentation of complex images based on component-trees: Methodological tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Component-trees can be used for the design of image processing methods, and in particular segmentation ones. However, despite their ability to consider various kinds of knowledge and their tractable computation, methodological deadlocks often forbid to efficiently involve them in real applications. In this article, we explore new solutions to some of these deadlocks, and more especially those related to (i) complexity of the structures of interest and (ii) multiple knowledge handling. The usefulness of the proposed strategies is illustrated by preliminary results related to vessel segmentation from 3-D angiographic data.
Caldairou_ISMM_2009.pdf (158.84 Ko) Télécharger le fichier
inria-00412967 , version 1 (28-02-2018)
Benoît Caldairou, Benoît Naegel, Nicolas Passat. Segmentation of complex images based on component-trees: Methodological tools. International Symposium on Mathematical Morphology (ISMM), 2009, Groningen, Netherlands. pp.171-180, ⟨10.1007/978-3-642-03613-2_16⟩. ⟨inria-00412967⟩
135 Consultations
149 Téléchargements
