Valence-driven connectivity encoding of 3d meshes, Eurographics 2001 Conference Proceedings, pp.480-489, 2001. ,
Interactive geometry remeshing, SIGGRAPH conference proceedings, pp.347-354, 2002. ,
Mesh Generation and Optimal Triangulation Computing in Euclidean Geometry, pp.23-90, 1992. ,
Mesh Generation, Chapter, 1999. ,
DOI : 10.1016/B978-044482537-7/50007-3
Coarse-to-fine Surface Simplification with Geometric Guarantees, Eurographics proceedings, pp.490-499, 2001. ,
Mesh Gradation Control, Proceedings of 6th International Meshing Roundtable, pp.131-141, 1997. ,
Resampling Feature and Blend Regions in Polygonal Meshes for Surface Anti-Aliasing, Eurographics proceedings, pp.402-410, 2001. ,
Feature Sensitive Sampling for Interactive Remeshing, Vision, Modeling and Visualization proceedings, pp.129-136, 2000. ,
Optimal system of loops on an orientable surface ,
Surface Meshing Using Vertex Insertion, Proceedings of 5th International Meshing Roundtable, pp.243-256, 1996. ,
Intrinsic parameterizations of surface meshes, Proceedings of Eurographics, pp.209-218, 2002. ,
Centroidal Voronoi Tesselations: Applications and Algorithms, SIAM review, vol.41, issue.4, pp.637-676, 1999. ,
Multiresolution Analysis of Arbitrary Meshes, Proceedings of SIGGRAPH, pp.173-182, 1995. ,
Optimally cutting a surface into a disk, Proceedings of the 18th Annual ACM Symposium on Computational Geometry, pp.244-253, 2002. ,
An adaptive algorithm for spatial grey scale, Proc. of the Society for Information Display, pp.75-77, 1976. ,
Simplifying Surfaces with Color and Texture using Quadric Error Metrics, IEEE Visualization Conference Proceedings, pp.263-269, 1998. ,
Delaunay Triangulation and Meshing Application to Finite Elements, 1998. ,
Geometry Images, Proceedings of SIGGRAPH, pp.355-361, 2002. ,
Multiresolution Signal Processing for Meshes, Proceedings of SIGGRAPH, pp.325-334, 1999. ,
Topological noise removal, Proceedings, of Graphics Interface, pp.19-26, 2001. ,
Remeshing Triangulated Surfaces with Optimal Parameterizations, Computer-Aided Design, vol.33, pp.779-788, 2001. ,
Multiresolution feature extraction from unstructured meshes, IEEE Visualization conf. proceedings, pp.287-294, 2001. ,
Error-Diffusion with Blue-Noise Properties for Midtones, SPIE, vol.4663, pp.293-301, 2002. ,
Progressive Geometry Compression, Proceedings of SIGGRAPH, pp.271-278, 2000. ,
A Shrink Wrapping Approach to Remeshing Polygonal Surfaces, Computer Graphics Forum, pp.99-18119, 1999. ,
Computing a ,
URL : https://hal.archives-ouvertes.fr/hal-00804691
MAPS: Multiresolution Adaptive Parameterization of Surfaces, Proceedings of SIGGRAPH, pp.95-104, 1998. ,
Least Squares Conformal Maps for Automatic Texture Atlas Generation, Proceedings of SIGGRAPH, pp.362-371, 2002. ,
Fast and Memory Efficient Polygonal Simplification, IEEE Visualization Proceedings, pp.279-286, 1998. ,
Discrete Differential- Geometry Operators for Triangulated 2-Manifolds, 2002. ,
Static polyhedron simplification using error measurements, Computer-Aided Design, vol.29, issue.4, pp.287-298, 1997. ,
DOI : 10.1016/S0010-4485(96)00057-7
Computing Discrete Minimal Surfaces and Conjugates, Experimental Mathematics, vol.2, issue.1, pp.15-36, 1993. ,
Surface Remeshing by Local Hermite Diffuse Interpolation, International Journal for numerical methods in Engineering, vol.49, pp.31-49, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00655134
Generating random points in a tetrahedron, Journal of Graphics tools, A.K. Peters Ltd, vol.5, issue.4, pp.9-12, 2000. ,
Signal-specialized parametrization, Eurographics Workshop on Rendering, 2002. ,
Advancing Front Surface Mesh Generation in Parametric Space Using a Riemannian Surface Definition, Proceedings of 7th International Meshing Roundtable, pp.429-445, 1998. ,
Feature Sensitive Remeshing, Eurographics proceedings, pp.393-401, 2001. ,
Detection of Salient Curvature Features on Polygonal Surfaces, Computer Graphics Forum. Eurographics, vol.20, issue.3, pp.385-392, 2001. ,
Fast Mesh Decimation by Multiple-Choice Techniques, Vision, Modeling and Visualization Proceedings, 2002. ,
