Convex Tours of Bounded Curvature. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geometry Année : 1999
We consider the motion planning problem for a point constrained to move along a smooth closed convex path of bounded curvature. The workspace of the moving point is bounded by a convex polygon with m vertices, containing an obstacle in a form of a simple polygon with n vertices. We present an O(m+n) time algorithm finding the path, going around the obstacle, whose curvature is the smallest possible.
bcdry-ctbc.pdf (227.28 Ko) Télécharger le fichier
inria-00413181 , version 1 (03-09-2009)
Jean-Daniel Boissonnat, Jurek Czyzowicz, Olivier Devillers, Jean-Marc Robert, Mariette Yvinec. Convex Tours of Bounded Curvature.. Computational Geometry, 1999, 13, pp.149-160. ⟨10.1016/S0925-7721(99)00022-X⟩. ⟨inria-00413181⟩
236 Consultations
139 Téléchargements
