Exploring New Horizons in Evolutionary Design of Robots
This introduction paper to the 2009 IROS workshop “Exploring new horizons in Evolutionary Design of Robots” considers the field of Evolutionary Robotics (ER) from the perspective of its potential users: roboticists. The core hypothesis motivating this field of research will be discussed, as well as the potential use of ER in a robot design process. Three main aspects of ER will be presented: (a) ER as an automatic parameter tuning procedure, which is the most mature application and is used to solve real robotics problem, (b) evolutionary-aided design, which may benefit the designer as an efficient tool to build robotic systems and (c) automatic synthesis, which corresponds to the automatic design of a mechatronic device. Critical issues will also be presented as well as current trends and pespectives in ER.
Intelligence artificielle [cs.AI]
