Non-preemptive multiprocessor scheduling for strict periodic systems with precedence constraints, Proceedings of the 23rd Annual Workshop of the UK Planning and Scheduling Special Interest Group, PLANSIG'04, 2004. ,
Scheduling and Load Balancing in Parallel and Distributed Systems, 1995. ,
Estimating capacity for sharing in a privately owned workstation environment, IEEE Transactions on Software Engineering, vol.18, issue.4, pp.319-328, 1992. ,
DOI : 10.1109/32.129220
A rapid heuristic for scheduling non-preemptive dependent periodic tasks onto multiprocessor, Proceedings of ISCA 20th international conference on Parallel and Distributed Computing Systems, PDCS'07, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00413486
Memory overflow protection for embedded systems using run-time checks, reuse, and compression, ACM Transactions on Embedded Computing Systems, vol.5, issue.4, pp.719-752, 2006. ,
DOI : 10.1145/1196636.1196637
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.3537
Allocation of periodic task modules with precedence and deadline constraints in distributed real-time systems, [1992] Proceedings Real-Time Systems Symposium, 1997. ,
DOI : 10.1109/REAL.1992.242668
A Lower-Bound Algorithm for Load Balancing in Real-Time Systems, Proceedings of the International Conference on Principles of Distributed Systems (OPODIS'03), 2003. ,
DOI : 10.1007/978-3-540-27860-3_15
A new algorithm for optimal bin packing, Eighteenth national conference on Artificial intelligence, pp.731-736, 2002. ,
Dynamic load-balancing via a genetic algorithm, Proceedings 13th IEEE International Conference on Tools with Artificial Intelligence. ICTAI 2001, p.121, 2001. ,
DOI : 10.1109/ICTAI.2001.974456
Memory resource considerations in the load balancing of software dsm systems, ICPP Workshops, pp.71-78, 2003. ,
Dynamic Application Placement Under Service and Memory Constraints, WEA, pp.391-402, 2005. ,
DOI : 10.1007/11427186_34
Cellular disco: resource management using virtual clusters on shared-memory multiprocessors, ACM Transactions on Computer Systems, vol.18, issue.3, pp.229-262, 2000. ,
DOI : 10.1145/354871.354873
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.40.7792
A heuristic approach to schedule periodic real-time tasks on reconfigurable hardware, International Conference on Field Programmable Logic and Applications, 2005., pp.568-573, 2005. ,
DOI : 10.1109/FPL.2005.1515787
Embedded system synthesis by timing constraints solving, Proceedings. Tenth International Symposium on System Synthesis (Cat. No.97TB100114), pp.50-57, 1997. ,
DOI : 10.1109/ISSS.1997.621675
An expert system for planning realtime distributed task allocation, Proceedings of the Florida AI Research Symposium, 1996. ,
Approximation algorithms for combinatorial optimization, Encyclopedia of Optimization, 2005. ,
