Asymptotically optimal worksharing in HNOWs: How long is "sufficiently long?, 36th Annual Simulation Symposium, pp.39-46, 2003. ,
On "exploiting" nodeheterogeneous clusters optimally. Theory of Computing Systems, vol.42, pp.465-487, 2008. ,
Fault-aware scheduling for bag-of-tasks applications on desktop grids, GRID '06, pp.56-63, 2006. ,
The interaction of parallel and sequential workloads on a network of workstations, SIGMETRICS '95/PERFORMANCE '95, pp.267-278, 1995. ,
Making commitments in the face of uncertainty: How to pick a winner almost every time, 28th ACM SToC, pp.519-530, 1996. ,
Efficient collective communication on heterogeneous networks of workstations, Intl. Conf. on Parallel Processing (ICPP), pp.460-467, 1998. ,
Scheduling strategies for master-slave tasking on heterogeneous processor platforms, IEEE Trans. Parallel Distributed Systems, vol.15, issue.4, pp.319-330, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00789427
Collection-aware optimum sequencing of operations and closed-form solutions for the distribution of a divisible load on arbitrary processor trees, IEEE Trans. Parallel Distrib. Syst, vol.9, issue.5, pp.429-441, 1998. ,
Bandwidth-centric allocation of independent tasks on heterogeneous platforms, 16th Intl. Parallel and Distributed Processing Symp. (IPDPS), 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072412
Scheduling divisible loads with return messages on heterogeneous master-worker platforms, Intl. Conf. on High Performance Computing HiPC'2005, vol.3769, pp.498-507, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02102504
Scheduling dags on asynchronous processors, 19th ACM SPAA, pp.35-45, 2007. ,
Scheduling Divisible Loads in Parallel and Distributed Systems, 1996. ,
An optimal strategies for cycle-stealing in networks of workstations, IEEE Trans. Computers, vol.46, issue.5, pp.545-557, 1997. ,
A case for economy grid architecture for service-oriented grid computing, 10th Heterogeneous Computing Workshop, 2001. ,
Distributed computation for a tree network with communication delays, IEEE Transactions on Aerospace and Electronic Systems, vol.26, issue.3, pp.511-516, 1990. ,
The computational co-op: Gathering clusters into a metacomputer, 13th Intl. Parallel Processing Symp. (IPPS), pp.160-166, 1999. ,
Master-slave tasking on heterogeneous processors, 17th Intl. Parallel and Distributed Processing Symp. (IPDPS), 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00001081
, The Grid 2: Blueprint for a New Computing Infrastructure, 2004.
The anatomy of the grid: Enabling scalable virtual organizations, Intl. J. High Performance Computing Applications, vol.15, issue.3, pp.200-222, 2001. ,
Efficient trigger-broadcasting in heterogeneous clusters, J. Parallel Distrib. Comput, vol.65, issue.5, pp.628-642, 2005. ,
Toward maximizing the quality of results of dependent tasks computed unreliably, Theory Comput. Syst, vol.41, issue.4, pp.731-752, 2007. ,
Multicast on irregular switch-based networks with wormhole routing, 3rd IEEE Symp. on High-Performance Computer Architecture, pp.48-57, 1997. ,
Scheduling Task Parallel Applications For Rapid Turnaround on Enterprise Desktop Grids, 2005. ,
Models and scheduling mechanisms for global computing applications, 16th Intl. Parallel and Distr. Processing Symp. (IPDPS), 2002. ,
Seti@home-massively distributed computing for seti, Computing in Science & Engineering, vol.3, issue.1, pp.78-83, 2001. ,
Condor -a hunter of idle workstations, ICDCS, pp.104-111, 1988. ,
Toward a theory for scheduling dags in internet-based computing, IEEE Trans. Computers, vol.55, issue.6, pp.757-768, 2006. ,
Modeling machine availability in enterprise and wide-area distributed computing environments, Euro-Par 2005 Parallel Processing, vol.3648, pp.432-441, 2005. ,
, Search of Clusters, 1995.
Experimental assessment of workstation failures and their impact on checkpointing systems, Fault-Tolerant Computing, pp.48-57, 1998. ,
Guidelines for data-parallel cycle-stealing in networks of workstations i: On maximizing expected output, J. Parallel Distrib. Comput, vol.59, issue.1, pp.31-53, 1999. ,
Guidelines for data-parallel cycle-stealing in networks of workstations ii: On maximizing guaranteed output, Intl. J. Foundations of Computer Science, vol.11, issue.1, pp.183-204, 2000. ,
Sharing partitionable workloads in heterogeneous nows: Greedier is not better, IEEE Intl. Conf. on Cluster Computing (CLUSTER 2001), pp.124-131, 2001. ,
Optimal schedules for cycle-stealing in a network of workstations with a bag-of-tasks workload, IEEE Trans. Parallel Distrib. Syst, vol.13, issue.2, pp.179-191, 2002. ,
Changing challenges for collaborative algorithmics, Handbook of Nature-Inspired and Innovative Computing: Integrating Classical Models with Emerging Technologies, pp.1-44, 2006. ,
Optimal sequencing and arrangement in distributed single-level tree networks with communication delays, IEEE Trans. Parallel Distrib. Syst, vol.5, issue.9, pp.968-976, 1994. ,
Multi-installment load distribution in tree networks with delays, IEEE Transactions on Aerospace and Electronic Systems, vol.31, issue.2, pp.555-567, 1995. ,
Use of a workstation cluster for the physical mapping of chromosomes, pp.14-17, 1993. ,
Probabilistic allocation of tasks on desktop grids, Proceedings of PCGrid, 2008. ,
Umr: A multi-round algorithm for scheduling divisible workloads, 17th Intl. Parallel and Distributed Processing Symp. (IPDPS), p.24, 2003. ,
