HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Mobility management in B3G networks: a middleware-based approach
Abstract : The B3G (Beyond 3G) networking will enable mobile users to roam freely through heterogeneous networks on an all-IP platform. However, mobility handling in such an environment poses new challenges. Traditionally, mobility protocols such as Mobile IP, SIP and SCTP are used to manage mobility in B3G, but they require telecommunication companies to either modify existing network infrastructures or deploy central entities in the network core to handle mobility. This is not feasible in a fully distributed computing environment (e.g., P2P) and mobile ad hoc networks that are part of B3G networking. As an alternative, this paper introduces a middleware component with modularized functionalities to facilitate mobility management in a fully distributed B3G environment.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00415918
Contributor : Valerie Issarny Connect in order to contact the contributor
Submitted on : Friday, September 11, 2009 - 2:45:55 PM
Last modification on : Friday, February 4, 2022 - 3:10:28 AM
Long-term archiving on: : Tuesday, June 15, 2010 - 8:08:31 PM
File
RongFIG07.pdf
Identifiers
  • HAL Id : inria-00415918, version 1
Collections
Citation
Letian Rong, Manel Fredj, Valérie Issarny, Nikolaos Georgantas. Mobility management in B3G networks: a middleware-based approach. International Workshop on the Engineering of Software Services for Pervasive Environments : ESSPE '07, 2007, Dubrovnik, Croatia. pp.41-45. ⟨inria-00415918⟩
Share
Metrics
Record views
74
Files downloads
50
