Irregular to Regular Sampling, Denoising, and Deconvolution, Multiscale Modeling & Simulation, vol.7, issue.4, pp.1574-1608, 2009. ,
DOI : 10.1137/080719443
URL : https://hal.archives-ouvertes.fr/hal-00988783
An algorithm for total variation minimization and applications, Journal of Mathematical Imaging and Vision, vol.20, pp.89-97, 2004. ,
Total variation based image restoration with free local constraints, Proceedings of 1st International Conference on Image Processing, pp.31-35, 1994. ,
DOI : 10.1109/ICIP.1994.413269
Satellite image reconstruction from an irregular sampling, 2008 IEEE International Conference on Acoustics, Speech and Signal Processing, 2008. ,
DOI : 10.1109/ICASSP.2008.4517743
URL : https://hal.archives-ouvertes.fr/inria-00278919
Efficient minimization methods of mixed l 1 ?l 1 and l 2 ?l 1 norms for image restoration, SIAM Journal on Scientific computing, vol.27, issue.6, 2006. ,
A Variational Approach to Remove Outliers and Impulse Noise, Journal of Mathematical Imaging and Vision, vol.20, issue.1/2, pp.99-120, 2004. ,
DOI : 10.1023/B:JMIV.0000011920.58935.9c
On the Fast Fourier Transform of Functions with Singularities, Applied and Computational Harmonic Analysis, vol.2, issue.4, pp.363-381, 1995. ,
DOI : 10.1006/acha.1995.1026
The dual-tree complex wavelet transform, IEEE Signal Processing Magazine, vol.22, issue.6, pp.123-151, 2005. ,
Gradient methods for minimizing composite objective function, CORE Discussion Paper, vol.76, 2007. ,
Algorithmes rapides d'optimisation convexe Application la reconstruction d'images et la détection de changements, 2008. ,
Information-based complexity of linear operator equations, Journal of Complexity, vol.8, issue.2, pp.153-175, 1992. ,
DOI : 10.1016/0885-064X(92)90013-2
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
Nonlinear wavelet image processing: variational problems, compression, and noise removal through wavelet shrinkage, IEEE Transactions on Image Processing, vol.7, issue.3, pp.319-335, 1996. ,
DOI : 10.1109/83.661182
Image decomposition via the combination of sparse representations and a variational approach, IEEE Transactions on Image Processing, vol.14, issue.10, pp.1570-1582, 2005. ,
DOI : 10.1109/TIP.2005.852206
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1999. ,
DOI : 10.1137/S1064827596304010
Analysis versus synthesis in signal priors, Inverse Problems, vol.23, issue.3, pp.947-968, 2007. ,
DOI : 10.1088/0266-5611/23/3/007
A variational formulation for frame-based inverse problems, Inverse Problems, vol.23, issue.4, pp.1495-1518, 2007. ,
DOI : 10.1088/0266-5611/23/4/008
URL : https://hal.archives-ouvertes.fr/hal-00621883
