HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Assimilation of Lagrangian Data in a Variational framework
Claire Chauvin 1 François-Xavier Le Dimet 1 Maëlle Nodet 1 Innocent Souopgui 1 Olivier Titaud 1 Arthur Vidard 1
1 MOISE - Modelling, Observations, Identification for Environmental Sciences
Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann, Inria Grenoble - Rhône-Alpes
Abstract : We present a review of our work on Lagrangian Data Assimilation in a Variational Framework. The Variational Data Assimilation aims at finding an optimal trajectory, solution of a given model, that is consistant with past observations of the modelled system. The observations we are interested in assimilating are of Lagrangian type: float positions (whose dynamics contain local physical information) and images. Satellite observations of atmosphere and ocean contain a huge quantity of visual information (such as eddies, fronts) that is underused by numerical forecasting systems. The construction of the observation operator is done thanks to passive tracers, whose dynamics are interpreted as an image. The turbulent structure of this image is then compared to the observed image, both of them being represented in a set of curvlets. After a short presentation of the several steps of our method, and more especially the Image Assimilation techniques, we will present the first results on twins experiments.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00418719
Contributor : Maëlle Nodet Connect in order to contact the contributor
Submitted on : Monday, September 21, 2009 - 2:44:27 PM
Last modification on : Thursday, January 20, 2022 - 4:16:32 PM
Identifiers
  • HAL Id : inria-00418719, version 1
Collections
Citation
Claire Chauvin, François-Xavier Le Dimet, Maëlle Nodet, Innocent Souopgui, Olivier Titaud, et al.. Assimilation of Lagrangian Data in a Variational framework. LAPCOD 2009 - Lagrangian Analysis and Prediction of Coastal and Ocean Dynamics, Sep 2009, La Londe Les Maures, France. ⟨inria-00418719⟩
Share
Metrics
Record views
103
