About the Lyapunov exponent of sampled-data systems with non-uniform sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we propose a method for evaluating the Lyapunov exponent of sampled-data systems with sampling jitter. We consider the case of systems in which the sampling interval is unknown, time-varying and bounded in a given interval. In order to take into account the inter-sampling behaviour of the system, the problem is addressed from the continuous time point of view. The approach exploits the fact that the command is a piecewise constant signal and leads to less conservative stability conditions. Using geometrical arguments, a lower bound of the Lyapunov exponent can be expressed as a generalized eigenvalue problem. Numerical examples are given to illustrate the approach.
Automatique
Fichier non déposé
inria-00419444 , version 1 (23-09-2009)
  • HAL Id : inria-00419444 , version 1
Laurentiu Hetel, Alexandre Kruszewski, Jean-Pierre Richard. About the Lyapunov exponent of sampled-data systems with non-uniform sampling. TDS'09, 8th IFAC Workshop on Time Delay Systems, Sep 2009, Sinaia, Romania. ⟨inria-00419444⟩
169 Consultations
0 Téléchargements
