C. M. Bibliographie and R. V. , « Optimizing the Error Recovery Capabilities of LDPC-staircase Codes Featuring a Gaussian Elimination Decoding Scheme, 10th IEEE International Workshop on Signal Processing for Space Communications (SPSC'08), 2008.
J. D. Divsalar and . J. Mceliece-r, « Coding theorems for " turbo-like " codes, Proceedings Thirty-Sixth Annual Allerton Conference on Communication, Control, and Computing, 1998.
[. Parchive, Parity Archive Volume Set
. Rizzo-l, Effective erasure codes for reliable computer communication protocols, ACM SIGCOMM Computer Communication Review, vol.27, issue.2, 1997.
DOI : 10.1145/263876.263881
R. V. Neumann-c and F. D. , « Low Density Parity Check (LDPC) Staircase and Triangle Forward Error Correction (FEC) Schemes, 2008.
S. A. Lassen-s and . Karp-r, « Systems and Processes for Decoding Chain Reaction Codes Through Inactivation, U.S. Patent Number, vol.6856, p.263, 2005.
W. M. Fountain, Inc.'s statement about IPR claimed in draft-ietf-rmt-bb-fec-raptor- object-04.txt, 2006.
