Complex abelian varieties, Grundlehren der mathematischen Wissenschaften, 2004. ,
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.3-4, 1997. ,
DOI : 10.1006/jsco.1996.0125
Factorization of polynomials in several variables, Proceedings of the 15th Scandinavian Congress, pp.1-17, 1968. ,
DOI : 10.1093/qmath/12.1.304
Factorisations explicities de g(y)?h(z), Acta Arithmetica, vol.87, issue.4, pp.291-317, 1999. ,
A note on the existence of absolutely simple Jacobians, Journal of Pure and Applied Algebra, vol.155, issue.2-3, pp.115-120, 2001. ,
DOI : 10.1016/S0022-4049(99)00096-1
Automorphisms of symmetric balanced incomplete block designs, Mathematische Zeitschrift, vol.21, issue.1, pp.40-49, 1970. ,
DOI : 10.1007/BF01109892
On symmetric balanced incomplete block designs with doubly transitive automorphism groups, Journal of Combinatorial Theory, Series A, vol.14, issue.2, pp.14-221, 1973. ,
DOI : 10.1016/0097-3165(73)90024-1
Some consequences of the classification of finite simple groups, Proceedings of Symposia in Pure Math, pp.175-181, 1980. ,
DOI : 10.1090/pspum/037/604576
On a conjecture of Schur, Michigan Math, J, vol.17, pp.41-55, 1970. ,
The field of definition of function fields and a problem in the reducibility of polynomials in two variables, Illinois J. Math, pp.17-128, 1973. ,
Exposition on an arithmetic-group theoretic connection via Riemann???s existence theorem, Proceedings of Symposia in Pure Math, pp.571-602, 1980. ,
DOI : 10.1090/pspum/037/604636
Implementation of Kedlaya's algorithm ,
Diophantine geometry: an introduction, 2000. ,
DOI : 10.1007/978-1-4612-1210-2
On the Existence of Absolutely Simple Abelian Varieties of a Given Dimension over an Arbitrary Field, Journal of Number Theory, vol.92, issue.1, pp.139-163, 2002. ,
DOI : 10.1006/jnth.2001.2697
Counting points on hyperelliptic curves using Monsky?Washnitzer cohomology, J. Ramanujan Math. Soc, vol.16, issue.4, pp.323-338, 2001. ,
Efficiently Computable Endomorphisms for Hyperelliptic Curves, Algorithmic number theory: proceedings of ANTS-VII, pp.495-509, 2006. ,
DOI : 10.1007/11792086_35
URL : https://hal.archives-ouvertes.fr/inria-00537882
Construction of algebraic correspondences between hyperelliptic function fields using Deuring's theory, 2004. ,
An explicit formula for the arithmetic geometric mean in genus 3, Experimental Math, pp.421-440, 2007. ,
Dickson polynomials, Pitman monographs and surveys in pure and applied mathematics 65, Longman Scientific and Technical, 1993. ,
Couples de jacobiennes isogénes de courbes hyperelliptiques de genre arbitraire ,
Abelian varieties with complex multiplication and modular functions, Princeton mathematical series 46, 1998. ,
Explicit endomorphisms and Correspondences, Bulletin of the Australian Mathematical Society, vol.74, issue.03, 2006. ,
DOI : 10.1017/S0004972700040521
Isogenies and the discrete logarithm problem in Jacobians of genus 3 hyperelliptic curves, EUROCRYPT 2008, pp.163-180, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00537860
Explicit hyperelliptic curves with real multiplication and permutation polynomials, Canad, J. Math, vol.43, issue.5, pp.1055-1064, 1991. ,
