Belief Merging-based Case Combination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Julien Cojan
  • Fonction : Auteur
  • PersonId : 836380
Jean Lieber
Integrity constraint belief merging aims at producing from several knowledge bases, that may be mutually inconsistent, a synthetic knowledge base satisfying a given integrity constraint. It is applied here to case combination for case-based reasoning. This approach is shown to extend Eyke Hüllermeier's credible case-based inference and to be reducible under some assumptions to linear programming.
iccbr09_submission_106.pdf (175.8 Ko) Télécharger le fichier
inria-00421724 , version 1 (02-10-2009)
Julien Cojan, Jean Lieber. Belief Merging-based Case Combination. 8th International Conference on Case-Based Reasoning - ICCBR 2009, Jul 2009, Seattle, United States. pp.105-119, ⟨10.1007/978-3-642-02998-1_9⟩. ⟨inria-00421724⟩
97 Consultations
187 Téléchargements
