An algorithm for symmetric interval eigenvalue problem, Institut de recherche en informatique et systèmes aléatoires, 2000. ,
Zur Problematik der Hüllenbestimmung von Intervallgleichungssystemen, Interval Mathemantics: Proceedings of the International Symposium on Interval Mathemantics, pp.150-159, 1975. ,
DOI : 10.1007/3-540-07170-9_12
An Interval Analysis Based Study for the Design and the Comparison of Three-Degrees-of-Freedom Parallel Kinematic Machines, The International Journal of Robotics Research, vol.23, issue.6, pp.615-624, 2004. ,
DOI : 10.1177/0278364904044079
Independent component analysis, a new concept? Signal processing, pp.287-314, 1994. ,
The Interval Eigenvalue Problem, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.35, issue.1, pp.61-64, 1991. ,
DOI : 10.1002/zamm.19910710117
Interval analysis of vibrating systems, Journal of Sound and Vibration, vol.183, issue.4, pp.739-749, 1995. ,
DOI : 10.1006/jsvi.1995.0283
Principal component analysis on interval data, Computational Statistics, vol.104, issue.1, pp.343-363, 2006. ,
DOI : 10.1007/s00180-006-0267-6
Matrix computations, 1996. ,
The extreme eigenvalues and stability of real symmetric interval matrices, IEEE Transactions on Automatic Control, vol.37, issue.4, pp.532-535, 1992. ,
DOI : 10.1109/9.126593
An algorithm for addressing the real interval eigenvalue problem, Journal of Computational and Applied Mathematics, vol.235, issue.8, 2008. ,
DOI : 10.1016/j.cam.2010.11.022
Bounds on Real Eigenvalues and Singular Values of Interval Matrices, SIAM Journal on Matrix Analysis and Applications, vol.31, issue.4, 2009. ,
DOI : 10.1137/090753991
Matrix analysis, 1985. ,
Topics in matrix analysis, 1994. ,
DOI : 10.1017/CBO9780511840371
PROFIL/BIAS ? a C++ class library ,
Outer Interval Solution of the Eigenvalue Problem under General Form Parametric Dependencies, Reliable Computing, vol.39, issue.1, pp.121-140, 2006. ,
DOI : 10.1007/s11155-006-4875-1
Computing eigenvalue bounds of structures with uncertain-but-non-random parameters by a method based on perturbation theory, Communications in Numerical Methods in Engineering, vol.282, issue.1, pp.973-982, 2007. ,
DOI : 10.1002/cnm.936
Matrix analysis and applied linear algebra, 2000. ,
DOI : 10.1137/1.9780898719512
Bounds of eigenvalues for structures with an interval description of uncertain-but-non-random parameters, Chaos, Solitons & Fractals, vol.7, issue.3, pp.425-434, 1996. ,
DOI : 10.1016/0960-0779(95)00065-8
An approximate method for the standard interval eigenvalue problem of real non-symmetric interval matrices, Communications in Numerical Methods in Engineering, vol.31, issue.4, pp.239-251, 2001. ,
DOI : 10.1002/cnm.401
Sufficient Conditions for Regularity and Singularity of Interval Matrices, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.2, pp.437-445, 1998. ,
DOI : 10.1137/S0895479896310743
Interval Matrices: Singularity and Real Eigenvalues, SIAM Journal on Matrix Analysis and Applications, vol.14, issue.1, pp.82-91, 1993. ,
DOI : 10.1137/0614007
Bounds on Eigenvalues of Interval Matrices, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.78, issue.S3, pp.1049-1050, 1998. ,
DOI : 10.1002/zamm.19980781593
A handbook of results on interval linear problems, 2005. ,
Zur Einschliessung der Eigenwerte einer Intervallmatrix, Computing, vol.70, issue.3-4, pp.373-377, 1992. ,
DOI : 10.1007/BF02320205
Solving algebraic problems with high accuracy A new approach to scientific computation, Proc. Symp, pp.51-120, 1983. ,
The algebraic eigenvalue problem. 1. paperback ed, 1988. ,
An evolution strategy method for computing eigenvalue bounds of interval matrices, Applied Mathematics and Computation, vol.196, issue.1, pp.257-265, 2008. ,
DOI : 10.1016/j.amc.2007.05.051
