An overview of Non Smooth Dynamical Systems. Moreau's Sweeping Process, Higher order systems and links with optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The non smooth approach is based on the Moreau's Sweeping process and its variants. The key idea is to write a right approximation of measures on a finite in- terval, and this leads efficient and robust numerical schemes, called Time–stepping schemes. The first algorithm was the “Catching up algorithm”. In the framework of multi-body dynamics, the derived algorithm is the ”Non Smooth Contact Dy- namics” method[13, 14, 7] which is able to treat several thousands of 3D frictional contact conditions. The time step is no longer of events but only fixed by a a priori error criterion. Therefore, accumulations of events or a large number of events in finite time are handled without difficulties. Furthermore, the convergence analy- sis of this family of schemes leads to existence of solutions for rather complicate systems [8, 16].
owr.pdf (66.47 Ko) Télécharger le fichier
inria-00423541 , version 1 (23-10-2009)
  • HAL Id : inria-00423541 , version 1
Vincent Acary. An overview of Non Smooth Dynamical Systems. Moreau's Sweeping Process, Higher order systems and links with optimization. Optimization and its applications., Jan 2005, Oberwolfach, Germany. ⟨inria-00423541⟩
85 Consultations
507 Téléchargements
