Implicit Euler numerical simulation of sliding mode systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper it is shown that the implicit Euler time-discretization of some classes of switching systems with sliding modes, yields a very good stabilization of the trajectory and of its derivative on the sliding surface. Therefore the spurious oscillations which are pointed out elsewhere when an explicit method is used, are avoided. Moreover the method (an event-capturing, or time-stepping algorithm) allows for accumulation of events (Zeno phenomena) and for multiple switching surfaces (i.e., a sliding surface of codimension ≥ 2). The details of the implementation are given, and numerical examples illustrate the developments. This method may be an alternative method for chattering suppression, keeping the intrinsic discontinuous nature of the dynamics on the sliding surfaces. Links with discrete-time sliding mode controllers are studied.
VABB.pdf (255.51 Ko) Télécharger le fichier
inria-00423549 , version 1 (08-11-2017)
  • HAL Id : inria-00423549 , version 1
Vincent Acary, Bernard Brogliato. Implicit Euler numerical simulation of sliding mode systems. Conference on Scientific Computing. Conference in honour of E. Hairer's 60th birthday, Martin Gander, Christian Lubich and Gerhard Wanner, Jun 2009, Geneva, Switzerland. ⟨inria-00423549⟩
134 Consultations
161 Téléchargements
