´´A´´A generalized newton method for contact problems with friction µµ, ´´Adhesion´´Adhesion and friction model for the fibre/matrix interface of a composite µµ, Third biennal Joint Comference on engineering system design and analysis, pp.67-82, 1988. ,
´´Interface´´Interface debonding model : a viscous regularization with a limited rate dependency µµ, Int. J. Solids Structures, vol.à paraître, 2000. ,
´´A´´A numerical model for buckling and growth of delaminations in composite laminates µµ, Computer Meth. Appl. Mech. and Engrg, vol.89, pp.361-380, 1991. ,
´´Formulation´´Formulation and approximation of quasistatic frictional contact µµ, Int. J. Eng. Sci, vol.34, issue.7, pp.783-798, 1996. ,
´´On´´On the mechanics of delamination ans spalling in compressed films µµ, Int. J. Solids Structures, vol.20, issue.5, pp.455-466, 1984. ,
´´Consistent´´Consistent model coupling adhesion, friction and unilateral contact µµ, Computer Meth. Appl. Mech. and Engrg, vol.177, pp.3-4, 1999. ,
´´Numerical´´Numerical simulations of fast crack growth in brittle solids µµ, J. Mech. Phys. Solids, vol.42, issue.9, pp.1397-1434, 1994. ,
