Segmentation of Deformable Templates With Level Sets Characterized By Particle Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
In this work is presented a method for the segmentation of deformable structures using a formulation of level-sets with particles system. This results in an original energetic formulation, and leads to a fast and robust methodfor computing the segmentation. Initialization is performed with the help of skeleton techniques, providing a stable and coherent initialization. It is possible to add or delete particles during the minimization process, and the use of particles systems makes it possible to contemplate hierarchical representations. The global shape is then represented by few control points, and more precision is obtained by locally adding new particles.
Fichier non déposé
inria-00423796 , version 1 (12-10-2009)
Hussein Yahia, Jean-Paul Berroir. Segmentation of Deformable Templates With Level Sets Characterized By Particle Systems. ICPR - International Conference on Pattern Recognition, Aug 1998, Brisbane, Australia. pp.1421-1423, ⟨10.1109/ICPR.1998.711969⟩. ⟨inria-00423796⟩
Collections
INRIA INRIA2
43 Consultations
0 Téléchargements
