New interface
Conference papers
Reasons for a Pessimistic or Optimistic Message Logging Protocol in MPI Uncoordinated Failure Recovery
Aurélien Bouteiller 1 Thomas Ropars 2 George Bosilca 1 Christine Morin 2 Jack Dongarra 1
2 PARIS - Programming distributed parallel systems for large scale numerical simulation
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, ENS Cachan - École normale supérieure - Cachan, Inria Rennes – Bretagne Atlantique
Abstract : With the growing scale of high performance computing platforms, fault tolerance has become a major issue. Among the various approaches for providing fault tolerance to MPI applications, message logging has been proved to tolerate higher failure rate. However, this advantage comes at the expense of a higher overhead on communications, due to latency intrusive logging of events to a stable storage. Previous work proposed and evaluated several protocols relaxing the synchronicity of event logging to moderate this overhead. Recently, the model of message logging has been refined to better match the reality of high performance network cards, where message receptions are decomposed in multiple interdependent events. According to this new model, deterministic and non-deterministic events are clearly discriminated, reducing the overhead induced by message logging. In this paper we compare, experimentally, a pessimistic and an optimistic message logging protocol, using this new model and implemented in the Open MPI library. Although pessimistic and optimistic message logging are, respectively, the most and less synchronous message logging paradigms, experiments show that most of the time their performance is comparable.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00424017
Contributor : Thomas Ropars Connect in order to contact the contributor
Submitted on : Tuesday, October 13, 2009 - 4:57:41 PM
Last modification on : Saturday, November 19, 2022 - 3:43:05 AM
Identifiers
  • HAL Id : inria-00424017, version 1
Citation
Aurélien Bouteiller, Thomas Ropars, George Bosilca, Christine Morin, Jack Dongarra. Reasons for a Pessimistic or Optimistic Message Logging Protocol in MPI Uncoordinated Failure Recovery. IEEE International Conference on Cluster Computing (Cluster 2009), Sep 2009, New Orleans, United States. ⟨inria-00424017⟩
Share
Metrics
Record views
166
