Algebraic switching time identification for a class of linear hybrid systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, a method for the finite time estimation of the switching times in linear switched systems is proposed. The approach is based on algebraic tools (differential algebra, module theory and operational calculus) and distribution theory. Switching time estimates are given by explicit algebraic formulae that can be implemented in a straightforward manner using standard tools from computational mathematics. Simulations illustrate the proposed techniques.
Automatique
ifacconf.pdf (131.99 Ko) Télécharger le fichier
inria-00424440 , version 1 (15-10-2009)
Yang Tian, Thierry Floquet, Lotfi Belkoura, Wilfrid Perruquetti. Algebraic switching time identification for a class of linear hybrid systems. ADHS'09 - IFAC Conference on Analysis and Design of Hybrid Systems, Sep 2009, Saragosse, Spain. ⟨10.1016/j.nahs.2010.07.003⟩. ⟨inria-00424440⟩
274 Consultations
345 Téléchargements
