Towards a Unified Framework for Declarative Structured Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proc. of PLACES'09 Année : 2009
We describe a unified framework for the declarative analysis of structured communications. By relying on a (timed) concurrent constraint programming language, we show that in addition to the usual operational techniques from process calculi, the analysis of structured communications can elegantly exploit logic-based reasoning techniques. In this work, we present a concurrent constraint interpretation of the language for structured communications proposed by Honda, Vasconcelos, and Kubo. Distinguishing features of our approach are: the possibility of including partial information (constraints) in the session model; the use of explicit time for reasoning about session duration and expiration; a tight correspondence with logic, which formally relates session execution and linear-time temporal logic formulas.
sessions-pub.pdf (177.44 Ko) Télécharger le fichier
inria-00426609 , version 1 (27-10-2009)
inria-00426609 , version 2 (17-11-2009)
  • HAL Id : inria-00426609 , version 1
Lopez Hugo, Carlos Olarte, Perez Jorge. Towards a Unified Framework for Declarative Structured Communications. Proc. of PLACES'09, 2009. ⟨inria-00426609v1⟩
160 Consultations
274 Téléchargements
