Building Extraction and Change Detection in Multitemporal Aerial and Satellite Images in a Joint Stochastic Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Csaba Benedek
  • Fonction : Auteur
  • PersonId : 840313
Xavier Descombes
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
In this report we introduce a new probabilistic method which integrates building extraction with change detection in remotely sensed image pairs. A global optimization process attempts to find the optimal configuration of buildings, considering the observed data, prior knowledge, and interactions between the neighboring building parts. The accuracy is ensured by a Bayesian object model verification, meanwhile the computational cost is significantly decreased by a non-uniform stochastic object birth process, which proposes relevant objects with higher probability based on low-level image features.
benedekRR.pdf (3.45 Mo) Télécharger le fichier
inria-00426615 , version 1 (27-10-2009)
inria-00426615 , version 2 (08-12-2009)
inria-00426615 , version 3 (13-12-2009)
  • HAL Id : inria-00426615 , version 1
Csaba Benedek, Xavier Descombes, Josiane Zerubia. Building Extraction and Change Detection in Multitemporal Aerial and Satellite Images in a Joint Stochastic Approach. [Research Report] 2009. ⟨inria-00426615v1⟩
456 Consultations
850 Téléchargements
