Improving the Performance of Virtual Memory Computers, 1978. ,
Processor Performance Modeling using Symbolic Simulation, ISPASS 2008, IEEE International Symposium on Performance Analysis of Systems and software, pp.127-138, 2008. ,
DOI : 10.1109/ISPASS.2008.4510745
The polynomial method in circuit complexity, [1993] Proceedings of the Eigth Annual Structure in Complexity Theory Conference, pp.82-95, 1993. ,
DOI : 10.1109/SCT.1993.336538
Register Allocation: What does the NP-completeness Proof of Chaitin et al. Really Prove?, Fifth Annual Workshop on Duplicating, Deconstructing and Debunking (WDDD2006) (at ISCA-33), 2006. ,
Improvements to graph coloring register allocation, ACM Transactions on Programming Languages and Systems, vol.16, issue.3, pp.428-455, 1994. ,
DOI : 10.1145/177492.177575
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.253
Improved performance of IBM Enterprise System/9000 bipolar logic chips, IBM J. Res. Dev, vol.36, issue.5, pp.829-834, 1992. ,
Closed iterative calculus, Theoretical Computer Science, pp.371-378, 1996. ,
DOI : 10.1016/0304-3975(95)00171-9
URL : http://doi.org/10.1016/0304-3975(95)00171-9
In Situ Design of Register Operations, 2008 IEEE Computer Society Annual Symposium on VLSI, pp.287-292, 2008. ,
DOI : 10.1109/ISVLSI.2008.62
URL : https://hal.archives-ouvertes.fr/lirmm-00287659
Three generators for minimal writing-space computations, Theoretical Informatics and Application, pp.131-138, 2000. ,
DOI : 10.1051/ita:2000110
URL : http://archive.numdam.org/article/ITA_2000__34_2_131_0.pdf
Quadratic Sequential Computations of Boolean Mappings, Theory of Computing Systems, pp.519-525, 2004. ,
DOI : 10.1007/s00224-003-1069-7
Sequential computation of linear Boolean mappings, Theoretical Computer Science, pp.287-292, 2004. ,
DOI : 10.1016/j.tcs.2003.11.027
Code optimization, 2007. ,
Register allocation & spilling via graph coloring, SIGPLAN '82: Proceedings of the 1982 SIGPLAN symposium on Compiler construction, pp.98-105, 1982. ,
DOI : 10.1145/800230.806984
Register allocation via coloring, Computer Languages, vol.6, issue.1, pp.47-57, 1981. ,
DOI : 10.1016/0096-0551(81)90048-5
Nonlinear array layouts for hierarchical memory systems, Proceedings of the 13th international conference on Supercomputing , ICS '99, pp.444-453, 1999. ,
DOI : 10.1145/305138.305231
An Unsolvable Problem of Elementary Number Theory, American Journal of Mathematics, vol.58, issue.2, pp.356-363, 1936. ,
DOI : 10.2307/2371045
C++ Program Design: An Introduction to Programming and Object-Oriented Design, 1997. ,
Boolean Functions -Theory, Algorithms, and Applications, 2008. ,
A Dictionary of Computing, 2004. ,
DOI : 10.1093/acref/9780199234004.001.0001
Putting the fill unit to work: dynamic optimizations for trace cache microprocessors, Proceedings. 31st Annual ACM/IEEE International Symposium on Microarchitecture, pp.173-181, 1998. ,
DOI : 10.1109/MICRO.1998.742779
Cache-oblivious algorithms (extended abstract), Proc. 40th Annual Symposium on Foundations of Computer Science, pp.285-397, 1999. ,
Iterated register coalescing, ACM Transactions on Programming Languages and Systems, vol.18, issue.3, pp.300-324, 1996. ,
DOI : 10.1145/229542.229546
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.4803
Graph colouring and applications. HabilitationàHabilitationà diriger des recherches, 2007. ,
Cole, Proceedings of the sixth annual IEEE/ACM international symposium on Code generation and optimization , CGO '08, 2008. ,
DOI : 10.1145/1356058.1356080
Microprocessor Hardware and Software Concepts, 1987. ,
Du Croz and I. Duff. A set of level 3 basic linear algebra subprograms, ACM Transactions on Mathematical Software, pp.1-17, 1990. ,
Ars Technicia: The PC Enthusiasts Resource, 2001. ,
The impact of hierarchical memory systems on linear algebra algorithm design, 1987. ,
The 21264: a superscalar alpha processor with out-of-order execution. 9th Annual Microprocessor Forum, 1996. ,
???ber Graphen und ihre Anwendung auf Determinantentheorie und Mengenlehre, Mathematische Annalen, vol.15, issue.4, pp.453-465, 1916. ,
DOI : 10.1007/BF01456961
The HP PA-8000 RISC CPU, Hot Chips VIII, 1996. ,
DOI : 10.1109/40.592310
The cache performance and optimizations of blocked algorithms, Proceedings of the Fourth International Conference on Architectural Support for Programming Languages and Operating Systems, pp.63-74, 1991. ,
Certain problems associated with boolean polynomials Computing Center, Russian academy of Sciences, ul, 1998. ,
The cache performance and optimization of blocked algorithms, The Sixth International Conference on Architectural Support for Programming Languages and Operating Systems, 1991. ,
The theory of error correcting codes, sole distributors for the U.S.A. and Canada, 1977. ,
Organizing matrices and matrix operations for paged memory systems, Communications of the ACM, vol.12, issue.3, pp.153-165, 1969. ,
DOI : 10.1145/362875.362879
Optimizing graph algorithms for improved cache performance, Proc. Intl Parallel and Distributed Processing Symp, pp.769-782, 2002. ,
Producing Computer Instructions for the PACT I Compiler, Journal of the ACM, vol.3, issue.4, 1956. ,
DOI : 10.1145/320843.320847
The Usage of Compiler Optimization by Programmers, Thesis, 2001. ,
Dynamic data layouts for cache-conscious factorization of DFT, Proceedings 14th International Parallel and Distributed Processing Symposium. IPDPS 2000, pp.693-701, 2000. ,
DOI : 10.1109/IPDPS.2000.846054
Trace cache: a low latency approach to high band-width instruction fetching, 29th International Symposium on Microarchitecture, pp.24-34, 1996. ,
On the decomposition of boolean functions via boolean equations. j-jucs, pp.1294-1301, 2004. ,
Compiler technology for migrating sequential code to multithreaded Architectures, 2006. ,
Compiler optimization for improving data locality, Proceedings of the Sixth International Conference on Architectural Support for Programming Languages and Operating Systems ,
Compiler techniques for code compaction, ACM Trans. on Programming Languages and Systems, vol.22, issue.2, pp.378-415, 2000. ,
Code optimization of parallel programs, Proceedings of the sixth annual IEEE/ACM international symposium on Code generation and optimization , CGO '08, pp.1-1, 2008. ,
DOI : 10.1145/1356058.1356087
Challenges in Code Optimization of Parallel Programs, CC, 2009. ,
DOI : 10.1007/978-3-642-00722-4_1
Principles of microprocessors, 1991. ,
A survey of compiler optimization techniques, Proceedings of the annual conference on , ACM'73, pp.106-113, 1973. ,
DOI : 10.1145/800192.805690
Towards a mathematical semantics for computer languages, 1971. ,
An Efficient Algorithm for Exploiting Multiple Arithmetic Units, IBM Journal of Research and Development, vol.11, issue.1, pp.25-233, 1967. ,
DOI : 10.1147/rd.111.0025
Computability and ??-definability, The Journal of Symbolic Logic, vol.42, issue.04, pp.153-163, 1937. ,
Automatically tuned linear algebra software, Supercomputing '98: Proceedings of the 1998 ACM/IEEE conference on Supercomputing (CDROM), pp.1-27, 1998. ,
DOI : 10.1109/sc.1998.10004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.3487
A data locality optimizing algorithm, The SIGPLAN'91 Conference on Programing Language Design and Implementation, pp.30-44, 1991. ,
More iteration space tiling, Proceedings of the 1989 ACM/IEEE conference on Supercomputing , Supercomputing '89, 1989. ,
DOI : 10.1145/76263.76337
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.578.5640
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4 ,
IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) ?tt??????????r????r ,
