Cosine Effect in Ocean Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This works aims at studying the impact of the cosine terms of the Coriolis force, that are usually neglected in geophysical fluid dynamics, leading to the so-called traditional approximation. Mathematical well-posedness arguments for simplified models, as well as numerical simulations, are presented in order to suggest the use of these terms in large scale ocean modelling.
Rousseau.pdf (425.37 Ko) Télécharger le fichier
inria-00428977 , version 1 (30-10-2009)
inria-00428977 , version 2 (11-02-2010)
  • HAL Id : inria-00428977 , version 1
Carine Lucas, Antoine Rousseau. Cosine Effect in Ocean Models. Oceanography and Mathematics, Jan 2009, Paris, France. ⟨inria-00428977v1⟩
Collections
CASCIMODOT
335 Consultations
362 Téléchargements
