HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Computing and updating the process number in trees
David Coudert 1 Florian Huc 1 Dorian Mazauric 1
1 MASCOTTE - Algorithms, simulation, combinatorics and optimization for telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : The process number is the minimum number of requests that have to be simultaneously disturbed during a routing reconfiguration phase of a connection oriented network. From a graph theory point of view, it is similar to the node search number, and thus to the pathwidth, however they are not always equal. In general determining these parameters is NP-complete. We present a distributed algorithm to compute these parameters and the edge search number, in trees. It can be executed in an asynchronous environment, requires n steps, an overall computation time of O(n log n), and n messages of size log3 n + 2. Then, we propose a distributed algorithm to update these parameters on each component of a forest after addition or deletion of any tree edge. This second algorithm requires O(D) steps, an overall computation time of O(D log n), and O(D) messages of size log3 n + 3, where D is the diameter of the new connected component.
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00429149
Contributor : David Coudert Connect in order to contact the contributor
Submitted on : Saturday, October 31, 2009 - 4:03:20 PM
Last modification on : Friday, February 4, 2022 - 3:15:51 AM
Long-term archiving on: : Tuesday, October 16, 2012 - 1:01:55 PM
File
opodis08-nostyle.pdf
Identifiers
Collections
Citation
David Coudert, Florian Huc, Dorian Mazauric. Computing and updating the process number in trees. 12th International Conference On Principles Of DIstributed Systems (OPODIS), Dec 2008, Luxor, Egypt. ⟨10.1007/978-3-540-92221-6_37⟩. ⟨inria-00429149⟩
Share
Metrics
Record views
117
Files downloads
168
