Traffic Grooming in Unidirectional WDM Ring Networks using Design Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We address the problem of traffic grooming in WDM rings with all-to-all uniform unitary traffic. We want to minimize the total number of SONET add-drop multiplexers (ADMs) required. We show that this problem corresponds to a partition of the edges of the complete graph into subgraphs, where each subgraph has at most C edges (where C is the grooming ratio) and where the total number of vertices has to be minimized. Using tools of graph and design theory, we optimally solve the problem for practical values and infinite congruence classes of values for a given C , and thus improve and unify all the preceding results. We disprove a conjecture of [7] saying that the minimum number of ADMs cannot be achieved with the minimum number of wavelengths, and also another conjecture of [17].
BC-ICC03.pdf (96.98 Ko) Télécharger le fichier
inria-00429174 , version 1 (01-11-2009)
Jean-Claude Bermond, David Coudert. Traffic Grooming in Unidirectional WDM Ring Networks using Design Theory. IEEE International Conference on Communications (ICC '03)., May 2003, Anchorage, United States. pp.1402 - 1406, ⟨10.1109/ICC.2003.1204621⟩. ⟨inria-00429174⟩
125 Consultations
188 Téléchargements
