Network Flows, Awd99] D. O. Awduche. MPLS and Traffic Engineering in IP Networks. IEEE Communications Magazine, pp.42-47, 1993. ,
Communications dans les réseaux optiques par multiplexage en longueur d'onde, 2000. ,
Introduction to Algorithms A note on two problems in connexion with graphs, Numerische Mathematik, vol.1, pp.269-271, 1959. ,
Fibonacci heaps and their uses in improved network optimization algorithms, Journal of the ACM, vol.34, issue.3, pp.596-615, 1987. ,
DOI : 10.1145/28869.28874
An O(n2(m + Nlog n)log n) min-cost flow algorithm, Journal of the ACM, vol.35, issue.2, pp.374-386, 1988. ,
DOI : 10.1145/42282.214090
URL : http://academiccommons.columbia.edu/download/fedora_content/download/ac:142124/CONTENT/CUCS-302-87.pdf
Routing dependable connections with specified failure restoration guarantees in WDM networks, Proceedings IEEE INFOCOM 2000. Conference on Computer Communications. Nineteenth Annual Joint Conference of the IEEE Computer and Communications Societies (Cat. No.00CH37064), pp.1761-1770, 2000. ,
DOI : 10.1109/INFCOM.2000.832576
Protection/Restoration of MPLS Networks. work in progress, Internet Draft draft-makam-mpls-protection-00.txt, 1999. ,
A faster strongly polynominal minimum cost flow algorithm, Proceedings of the 20th ACM Symposium on Theory of Computing, pp.377-387, 1988. ,
DOI : 10.1287/opre.41.2.338
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.1933
An Incremental Algorithm for a Generalization of the Shortest-Path Problem, Journal of Algorithms, vol.21, issue.2, pp.267-305, 1996. ,
DOI : 10.1006/jagm.1996.0046
A polynomial-time algorithm for the establishment of primary and alternate paths in ATM networks, Proceedings IEEE INFOCOM 2000. Conference on Computer Communications. Nineteenth Annual Joint Conference of the IEEE Computer and Communications Societies (Cat. No.00CH37064), pp.509-518, 2000. ,
DOI : 10.1109/INFCOM.2000.832224
A quick method for finding shortest pairs of disjoint paths. Networks, pp.325-336, 1984. ,
Efficient network upgrade based on a WDM optical layer with automatic protection switching, OFC '98. Optical Fiber Communication Conference and Exhibit. Technical Digest. Conference Edition. 1998 OSA Technical Digest Series Vol.2 (IEEE Cat. No.98CH36177), pp.22-27, 1998. ,
DOI : 10.1109/OFC.1998.657414
Survivability in optical networks, IEEE Network, vol.14, issue.6, pp.16-23, 2000. ,
