Hypergraphes: Combinatoire des ensembles nis, Bordas, 1987. ,
Strategies for interconnection networks: Some methods from graph theory, Journal of Parallel and Distributed Computing, vol.3, issue.4, p.1077123, 1989. ,
DOI : 10.1016/0743-7315(86)90008-0
Improved embeddings in POPS networks through stack-graph models, Proceedings of Massively Parallel Processing Using Optical Interconnections, p.1300135, 1996. ,
DOI : 10.1109/MPPOI.1996.559065
Optical Transpose Interconnection System for Vertical Emitters, OSA Topical Meeting on Optics in Computing, 1997. ,
Array interconnect systems based on lenslets and CGH, SPIE International Symposium on Optical Science, Engineering and Instrumentation, 1995. ,
A performance comparison between graph and hypergraph topologies for passive star WDM lightwave networks, Computer Networks and ISDN Systems, vol.30, issue.8, p.8055819, 1998. ,
DOI : 10.1016/S0169-7552(97)00125-6
Dense wavelength division multiplexing networks: principles and applications, IEEE Journal on Selected Areas in Communications, vol.8, issue.6, p.9477964, 1990. ,
DOI : 10.1109/49.57798
Multiprocessor interconnection networks using partitioned optical passive star (POPS) topologies and distributed control, First International Workshop on Massively Parallel Processing Using Optical Interconnections, p.14160111612, 1996. ,
DOI : 10.1109/MPPOI.1994.336637
Quadro-star: A high performance optical wdm star network, IEEE Transactions on Communications, vol.42, issue.8, p.258222591, 1994. ,
Multiprocessor Architectures Using Multihops Multi-OPS Lightwave Networks and Distributed Control, IEEE International Parallel Processing Symposium, p.1511155, 1998. ,
DOI : 10.1109/ipps.1998.669903
URL : https://hal.archives-ouvertes.fr/inria-00429196
Comparison between electrical and free-space optical interconnects based on power and speed considerations, Applied Optics, vol.27, issue.9, p.174221751, 1988. ,
Line Digraph Iterations and the (d, k) Digraph Problem, IEEE Transactions on Computers, vol.33, issue.5, pp.400-403, 1984. ,
DOI : 10.1109/TC.1984.1676455
Photorefractive Beamsplitter For Free Space Optical Interconnection systems, Applied Optics, issue.37, p.617886181, 1998. ,
DOI : 10.1117/12.274419
Design to Minimize Diameter on Building-Block Network, IEEE Transactions on Computers, vol.30, issue.6, p.304399442, 1981. ,
DOI : 10.1109/TC.1981.1675809
A Design for Directed Graphs with Minimum Diameter, IEEE Transactions on Computers, vol.32, issue.8, p.327822784, 1983. ,
DOI : 10.1109/TC.1983.1676323
Fault-tolerant processor interconnection networks, Systems and Computers in Japan, vol.66, issue.8, 1986. ,
DOI : 10.1002/scj.4690170803
Bounds on directed (d,k) graphs. Theory of cellular logic networks and machines. AFCRL-68-0668 Final report, pp.20-28, 1968. ,
Optical transpose interconnection system architectures, Optics Letters, vol.18, issue.13, p.108331085, 1993. ,
WDM-based local lightwave networks part I: Single-hop systems, IEEE Networks, p.12227, 1992. ,
DOI : 10.1109/65.139139
WDM-based local lightwave networks part II: Multi-hop systems, IEEE Networks, 1992. ,
DOI : 10.1109/65.145161
Lightwave Networks Based on de Bruijn Graphs, IEEE/ACM Transactions on Networking, vol.2, issue.1, p.70079, 1994. ,
DOI : 10.1109/90.282610
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.1387
Low threshold continuously tunable vertical-cavity surface-emitting lasers with 19.1 nm wavelength range, Applied Physics Letters, vol.70, issue.5, p.547, 1997. ,
DOI : 10.1063/1.119264
Scalable Network Architectures Using The Optical Transpose Interconnection System, Massively Parallel Processing using Optical Interconnections, p.1144121, 1996. ,
Performance analysis of multihop lightwave networks with hot potato routing and distance-age-priorities, IEEE INFCOM '91. The conference on Computer Communications. Tenth Annual Joint Comference of the IEEE Computer and Communications Societies Proceedings, p.257112581, 1994. ,
DOI : 10.1109/INFCOM.1991.147615
