Improved embeddings in POPS networks through stack-graph models, Proceedings of Massively Parallel Processing Using Optical Interconnections, pp.130-135, 1996. ,
DOI : 10.1109/MPPOI.1996.559065
Array interconnect systems based on lenslets and CGH, SPIE International Symposium on Optical Science, Engineering and Instrumentation, pp.2537-2559, 1995. ,
A performance comparison between graps and hypergraph topologies for passive star WDM lightwave networks. Computer Networks and ISDN Systems, To appear. A preliminary version, the Proceedings of the 2nd IEEE MPPOI, pp.257-264 ,
Multiprocessor interconnection networks using partitioned optical passive star (POPS) topologies and distributed control, First International Workshop on Massively Parallel Processing Using Optical Interconnections, pp.1601-1612, 1996. ,
DOI : 10.1109/MPPOI.1994.336637
Towards Effective Models for Optical Passive Star Based Lightwave Networks, Optical Interconnections and Parallel Processing: Trends at the Interface, 1997. ,
DOI : 10.1007/978-1-4757-2791-3_8
Line Digraph Iterations and the (d, k) Digraph Problem, IEEE Transactions on Computers, vol.33, issue.5, pp.400-403, 1984. ,
DOI : 10.1109/TC.1984.1676455
Photorefractive Beamsplitter For Free Space Optical Interconnections. SPIE Photonics West'97, Optoelectron- ics'97, Diffractive and Holographic Optics Technology IV, 1997. ,
Bounds on directed (d,k) graphs. Theory of cellular logic networks and machines. AFCRL-68-0668 Final report, pp.20-28, 1968. ,
WDM-based local lightwave networks. I. Single-hop systems, IEEE Network, vol.6, issue.3, pp.12-27, 1992. ,
DOI : 10.1109/65.139139
WDM-based local lightwave networks part II: Multihop systems, IEEE Networks, pp.20-32, 1992. ,
DOI : 10.1109/65.145161
An algorithm for generating node disjoint routes in Kautz digraphs, [1991] Proceedings. The Fifth International Parallel Processing Symposium, pp.102-107, 1991. ,
DOI : 10.1109/IPPS.1991.153763
Low threshold continuously tunable vertical-cavity surface-emitting lasers with 19.1 nm wavelength range, Applied Physics Letters, vol.70, issue.5, p.547, 1997. ,
DOI : 10.1063/1.119264
