Comparison between electrical and freespace optical interconnects based on power and speed considerations, OSA App. Opt, vol.27, issue.9, p.174221751, 1988. ,
Energy Requirement and Speed Analysis of Electrical and Free-Space Optical Digital Interconnections, Optical Interconnections and Parallel Processing: Trends at the Interface, p.499128, 1997. ,
DOI : 10.1007/978-1-4757-2791-3_3
Ultralow threshold VCSELs for application to smart pixels, Smart Pixels Technical Digest, 1996. ,
Low threshold continuously tunable vertical-cavity surface-emitting lasers with 19.1 nm wavelength range, Applied Physics Letters, vol.70, issue.5, p.547, 1997. ,
DOI : 10.1063/1.119264
Transimpedance receiver design optimization for smart pixel arrays, Journal of Lightwave Technology, vol.16, issue.1, p.1199126, 1998. ,
DOI : 10.1109/50.654993
Photorefractive Beamsplitter For Free Space Optical Interconnection Systems, OSA App. Opt, vol.37, issue.26, pp.61788-6181, 1998. ,
4 x 4 fan-out spot generator using GaAs based VCSEL's and diffractive optical element, IEEE Photonics Technology Letters, vol.9, issue.4, p.508, 1997. ,
DOI : 10.1109/68.559404
Optical transpose interconnection system architectures, Optics Letters, vol.18, issue.13, p.108331085, 1993. ,
DOI : 10.1364/OL.18.001083
Optical Transpose Interconnection System for Vertical Emitters, OSA Topical Meeting on Optics in Computing, 1997. ,
Scalable Network Architectures Using The Optical Transpose Interconnection System, Massively Parallel Processing using Optical Interconnections, p.1144121, 1996. ,
BPC permutations on the OTIS-Mesh optoelectronic computer, Proceedings of the Fourth International Conference on Massively Parallel Processing Using Optical Interconnections, p.1300135, 1997. ,
DOI : 10.1109/MPPOI.1997.609157
Randomized routing, selection, and sorting on the OTIS-mesh, IEEE Transactions on Parallel and Distributed Systems, vol.9, issue.9, p.8333840, 1998. ,
DOI : 10.1109/71.722217
Towards eeective models for Optical Passive Star based lightwave networks, Optical Interconnections and Parallel Processing: Trends at the Interface, p.2099233, 1997. ,
A performance comparison between graph and hypergraph topologies for passive star WDM lightwave networks, Computer Networks and ISDN Systems, vol.30, issue.8, p.8055819, 1998. ,
DOI : 10.1016/S0169-7552(97)00125-6
Quadro-star: A high performance optical WDM star network, IEEE Trans. on Comm, vol.42, issue.8, p.258222591, 1994. ,
The Rainbow-II gigabit optical network, IEEE Journal on Selected Areas in Communications, vol.14, issue.5, p.8144823, 1996. ,
DOI : 10.1109/49.510905
A comparative study of Shuue-Exhange, Manhattan Street and Supercube network for lightwave applications, Comp. Net. and ISDN Sys, vol.26, pp.10077-1022, 1994. ,
Performance analysis of multihop lightwave networks with hot potato routing and distance-age-priorities, IEEE INFCOM '91. The conference on Computer Communications. Tenth Annual Joint Comference of the IEEE Computer and Communications Societies Proceedings, pp.25711-2581, 1994. ,
DOI : 10.1109/INFCOM.1991.147615
Multiprocessor Architectures Using Multihops Multi-OPS Lightwave Networks and Distributed Control, IEEE International Parallel Processing Symposium, p.1511155, 1998. ,
DOI : 10.1109/ipps.1998.669903
URL : https://hal.archives-ouvertes.fr/inria-00429196
Bounds on directed (d,k) graphs. Theory of cellular logic networks and machines. AFCRL-68-0668, SRI Project 7258, 1968. ,
On multihop optical network topology using Kautz digraphs, Proceedings of INFOCOM'95, p.6755682, 1995. ,
DOI : 10.1109/INFCOM.1995.515935
The architecture of rattlesnake: A real-time multimedia network, In Lecture Notes in Computer Science, vol.712, p.15524, 1993. ,
DOI : 10.1007/3-540-57183-3_2
Rattlesnake a Single Chip High-Performance ATM switch, Proceedings of the International Conference on Multimedia and Networking (MmNet), p.2088217, 1995. ,
Multicast and Broadcast in the Rattlesnake ATM switch, Proceedings of the International Conference on Multimedia and Networking (MmNet), p.2188226, 1995. ,
Fault-tolerant processor interconnection networks, Systems and Computers in Japan, vol.66, issue.8, p.21130, 1986. ,
DOI : 10.1002/scj.4690170803
An algorithm for generating node disjoint routes in Kautz digraphs, [1991] Proceedings. The Fifth International Parallel Processing Symposium, pp.1022-107, 1991. ,
DOI : 10.1109/IPPS.1991.153763
Multiprocessor interconnection networks using partitioned optical passive star (POPS) topologies and distributed control, First International Workshop on Massively Parallel Processing Using Optical Interconnections, p.160111612, 1996. ,
DOI : 10.1109/MPPOI.1994.336637
Improved embeddings in POPS networks through stackgraph models, Massively Parallel Processing using Optical Interconnections, p.1300135, 1996. ,
Design to Minimize Diameter on Building-Block Network, IEEE Transactions on Computers, vol.30, issue.6, p.4399442, 1981. ,
DOI : 10.1109/TC.1981.1675809
A Design for Directed Graphs with Minimum Diameter, IEEE Transactions on Computers, vol.32, issue.8, p.7822784, 1983. ,
DOI : 10.1109/TC.1983.1676323
Array interconnect systems based on lenslets and CGH, SPIE International Symposium on Optical Science, Engineering and Instrumentation, 1995. ,
Inexpensive Local Interconnect Solutions Using Side-coupling Polymer Optical Fibers, Massively Parallel Processing using Optical Interconnections, p.45551, 1997. ,
Hypergraphes: Combinatoire des ensembles nis, Bordas, 1987. ,
"Hypermeshes": Optical Interconnection Networks for Parallel Computing, Journal of Parallel and Distributed Computing, vol.26, issue.1 ,
DOI : 10.1006/jpdc.1995.1043
An Abstract Model for Optical Interconnection Networks, Parallel Computing Using Optical Interconnections. Kluwer Academic, 1998. ,
DOI : 10.1007/978-0-585-27268-9_7
Line Digraph Iterations and the (d, k) Digraph Problem, IEEE Transactions on Computers, vol.33, issue.5, p.4000403, 1984. ,
DOI : 10.1109/TC.1984.1676455
Communications dans les rseaux de processeurs, 1994. ,
High uniformity 8 8 VCSEL arrays for optical interconnects, ECOC'99, pages II 3022303 24 2 A degree 4 optical passive star coupler. . . . . . . . . . . . . . . . . . . . . . 25, 1999. ,
