jSynoPSys - A Scenario-Based Testing Tool based on the Symbolic Animation of B Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Notes in Theoretical Computer Science Année : 2009
This paper presents the jSynoPSys tool that implements the concept of Scenario-Based Testing from B machines. This consists in describing execution scenarios, expressed as regular expressions over the operations of the system, coupled with intermediate system states that have to be reached when the scenario is unfolded. The tool relies on the BZ-Testing-Tools engine, originally designed to perform symbolic animation and boundary test generation from B machines. The main advantage of our Scenario-Based Testing technique is that it performs a full abstraction of the operation parameter values, that are instantiated at the end, when the scenario has been completely unfolded, using constraint solving techniques.
inria-00429234 , version 1 (02-11-2009)
Frédéric Dadeau, Régis Tissot. jSynoPSys - A Scenario-Based Testing Tool based on the Symbolic Animation of B Machines. Electronic Notes in Theoretical Computer Science, 2009, Proceedings of Fifth Workshop on Model Based Testing (MBT 2009), 253 (2), pp.117-132. ⟨10.1016/j.entcs.2009.09.055⟩. ⟨inria-00429234⟩
84 Consultations
0 Téléchargements
