Monte Carlo uncertainty analysis of a regional-scale transport chemistry model constrained by measurements from the Atmospheric Pollution Over the Paris Area (ESQUIF) campaign, Journal of Geophysical Research, vol.23, issue.D17, pp.10-1029, 2003. ,
DOI : 10.1029/2003JD003391
Development and validation of a fully modular platform for numerical modelling of air pollution: POLAIR, International Journal of Environment and Pollution, vol.22, issue.1/2, pp.17-28, 2004. ,
DOI : 10.1504/IJEP.2004.005474
URL : https://hal.archives-ouvertes.fr/inria-00527198
Science algorithms of the EPA models-3 community multiscale air quality (CMAQ) modeling system, 1999. ,
A three-dimensional Eulerian acid deposition model: Physical concepts and formulation, Journal of Geophysical Research, vol.21, issue.62, pp.14681-14700, 1987. ,
DOI : 10.1029/JD092iD12p14681
Technical Note: A new SIze REsolved Aerosol Model (SIREAM), ESQUIF: ´ Etude et simulation de la qualité de l'air en?Ileen?en?Ile de France ? rapport final, pp.1537-1547, 2001. ,
DOI : 10.5194/acp-7-1537-2007
URL : https://hal.archives-ouvertes.fr/hal-00328488
Sequential data assimilation with a nonlinear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, Journal of Geophysical Research, vol.109, issue.Part 4, pp.10143-10162, 1994. ,
DOI : 10.1029/94JC00572
Ensemble dispersion forecasting???Part I: concept, approach and indicators, Atmospheric Environment, vol.38, issue.28, pp.4607-4617, 2004. ,
DOI : 10.1016/j.atmosenv.2004.05.030
Comparison of the EMEP, RADM2 and RACM mechanisms, Journal of Atmospheric Chemistry, vol.44, issue.2, pp.151-170, 2003. ,
DOI : 10.1023/A:1022483412112
Monte carlo estimates of uncertainties in predictions by a photochemical grid model (UAM-IV) due to uncertainties in input variables, Atmospheric Environment, vol.32, issue.21, pp.3619-3628, 1998. ,
DOI : 10.1016/S1352-2310(97)00419-6
Uncertainties in predicted ozone concentrations due to input uncertainties for the UAM-V photochemical grid model applied to the July 1995 OTAG domain, Atmospheric Environment, vol.35, issue.5, pp.891-903, 1995. ,
DOI : 10.1016/S1352-2310(00)00367-8
A parametric model of vertical eddy fluxes in the atmosphere, Boundary-Layer Meteorology, vol.93, issue.2, pp.187-202, 1979. ,
DOI : 10.1007/BF00117978
Photodissociation in the atmosphere: 1. Actinic flux and the effects of ground reflections and clouds, Journal of Geophysical Research, vol.59, issue.D8, pp.9740-9752, 1987. ,
DOI : 10.1029/JD092iD08p09740
Ensemble-based air quality forecasts: A multimodel approach applied to ozone, Journal of Geophysical Research, vol.3, issue.D22, pp.10-1029, 2006. ,
DOI : 10.1029/2005JD006675
URL : https://hal.archives-ouvertes.fr/hal-00650980
Uncertainty in a chemistry-transport model due to physical parameterizations and numerical approximations: An ensemble approach applied to ozone modeling, Journal of Geophysical Research, vol.3, issue.D22, pp.10-1029, 2006. ,
DOI : 10.1029/2005JD006149
URL : https://hal.archives-ouvertes.fr/hal-00650907
Investigation of some numerical issues in a chemistry-transport model: Gas-phase simulations, Journal of Geophysical Research, vol.15, issue.2, pp.10-1029, 2007. ,
DOI : 10.1029/2006JD008373
URL : https://hal.archives-ouvertes.fr/inria-00633151
Technical Note: The air quality modeling system Polyphemus, Atmospheric Chemistry and Physics, vol.7, issue.20, pp.5479-5487, 2007. ,
DOI : 10.5194/acp-7-5479-2007-supplement
URL : https://hal.archives-ouvertes.fr/hal-00328547
Ozone ensemble forecast with machine learning algorithms, Journal of Geophysical Research, vol.41, issue.1, pp.530710-1029, 2009. ,
DOI : 10.1029/2008JD009978
URL : https://hal.archives-ouvertes.fr/inria-00565770
Assessment of an ensemble of seven real-time ozone forecasts over eastern North America during the summer of, J. Geophys. Res, p.10, 1029. ,
Oceanic Whitecaps ? and Their Role in Air-Sea Exchange Processes, chap. A model of marine aerosol generation via whitecaps and wave disruption, pp.167-174, 1986. ,
Application of dynamic linear regression to improve the skill of ensemble-based deterministic ozone forecasts, Atmospheric Environment, vol.40, issue.18, pp.3240-3250, 2006. ,
DOI : 10.1016/j.atmosenv.2006.02.006
MICS Asia Phase II???Sensitivity to the aerosol module, Atmospheric Environment, vol.42, issue.15, pp.3562-3570, 2008. ,
DOI : 10.1016/j.atmosenv.2007.03.005
URL : https://hal.archives-ouvertes.fr/hal-00142891
Data assimilation in atmospheric chemistry models using Kalman filtering, 2002. ,
Inventorying emissions from nature in Europe, and¨Oquistand¨ and¨Oquist, M. G.: Inventorying emissions from nature in Europe, pp.8113-8152, 1999. ,
DOI : 10.1029/98JD02747
The sea spray generation function, Journal of Aerosol Science, vol.29, pp.189-190, 1998. ,
DOI : 10.1016/S0021-8502(98)00280-8
The second generation regional acid deposition model chemical mechanism for regional air quality modeling, Journal of Geophysical Research, vol.18, issue.D10, pp.16343-16367, 1990. ,
DOI : 10.1029/JD095iD10p16343
A new mechanism for regional atmospheric chemistry modeling, Journal of Geophysical Research: Atmospheres, vol.25, issue.D22, pp.25847-25879, 1997. ,
DOI : 10.1029/97JD00849
A More Extensive Investigation of the Use of Ensemble Forecasts for Dispersion Model Evaluation, Journal of Applied Meteorology, vol.40, issue.3, pp.425-445, 2001. ,
DOI : 10.1175/1520-0450(2001)040<0425:AMEIOT>2.0.CO;2
A simple model of the atmospheric boundary layer; sensitivity to surface evaporation Evaluation of long-term ozone simulations from seven regional air quality models and their ensemble, Atmos. Environ, vol.37, issue.41, pp.129-148, 1986. ,
Numerical time integration for air pollution models, Surveys on Mathematics for Industry, vol.10, pp.107-174, 2002. ,
Parameterization of surface resistances to gaseous dry deposition in regional-scale numerical models, Atmospheric Environment (1967), vol.23, issue.6, pp.1293-1304, 1989. ,
DOI : 10.1016/0004-6981(89)90153-4
A revised parameterization for gaseous dry deposition in air-quality models, Atmospheric Chemistry and Physics, vol.3, issue.6, pp.2067-2082, 2003. ,
DOI : 10.5194/acp-3-2067-2003
URL : https://hal.archives-ouvertes.fr/hal-00295366
geosci-model-dev, Geosci. Model Dev, vol.69, issue.3, pp.69-85, 2010. ,
