Convolution Surfaces based on Polygonal Curve Skeletons. (An Application of Symbolic Integration to Graphics) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This paper reviews and generalizes Convolution Surfaces, a technique used in Computer Graphics to generate smooth 3D models around polygonal line serving as skeletons. Convolution surfaces are defined as level set of a function obtained by integrating a kernel function along this skeleton. To allow interactive modeling, the technique has relied on closed form formulae for integration obtained through symbolic computation software. This paper provides new qualitative results and generalizations on the topic. It is also an opportunity for us to introduce the field of convolution surfaces to the symbolic computation community, hoping that researchers well versed into integration techniques can bring additional contribution to this appealing shape representation.
HubertCaniOctober30.pdf (858.39 Ko) Télécharger le fichier
inria-00429358 , version 1 (02-11-2009)
inria-00429358 , version 2 (30-04-2010)
inria-00429358 , version 3 (17-11-2010)
  • HAL Id : inria-00429358 , version 1
Evelyne Hubert, Marie-Paule Cani. Convolution Surfaces based on Polygonal Curve Skeletons. (An Application of Symbolic Integration to Graphics). 2009. ⟨inria-00429358v1⟩
388 Consultations
936 Téléchargements
