Convolution Surfaces based on Polygonal Curve Skeletons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2012
This paper reviews and generalizes Convolution Surfaces, a technique used in Computer Graphics to generate smooth 3D volumes around skeletons that are lower dimensional or simpler geometric models of the shape to be created. Convolution surfaces are defined as level sets of a function obtained by integrating a kernel function along this skeleton. To allow interactive modeling, the technique has relied on closed form formulae for integration obtained through symbolic computation software.
HubertCani2010_11.pdf (1.86 Mo) Télécharger le fichier
inria-00429358 , version 1 (02-11-2009)
inria-00429358 , version 2 (30-04-2010)
inria-00429358 , version 3 (17-11-2010)
Evelyne Hubert, Marie-Paule Cani. Convolution Surfaces based on Polygonal Curve Skeletons. Journal of Symbolic Computation, 2012, Advances in Mathematics Mechanization, 47 (6), pp.680-699. ⟨10.1016/j.jsc.2011.12.026⟩. ⟨inria-00429358v3⟩
388 Consultations
926 Téléchargements
