On the Expressiveness of Probabilistic XML Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The VLDB Journal Année : 2009
Various known models of probabilistic XML can be represented as instantiations of the abstract notion of p-documents. In addition to ordinary nodes, p-documents have distributional nodes that specify the possibleworlds and their probabilistic distribution. Particular families of p-documents are determined by the types of distributional nodes that can be used as well as by the structural constraints on the placement of those nodes in a p-document. Some of the resulting families provide natural extensions and combinations of previously studied probabilistic XML models. The focus of the paper is on the expressive power of families of p-documents. In particular, two main issues are studied.
main.pdf (401.8 Ko) Télécharger le fichier
inria-00429498 , version 1 (04-11-2009)
  • HAL Id : inria-00429498 , version 1
Serge Abiteboul, Benny Kimelfeld, Y. Sagiv, Pierre Senellart. On the Expressiveness of Probabilistic XML Models. The VLDB Journal, 2009. ⟨inria-00429498⟩
173 Consultations
229 Téléchargements
