New interface
Conference papers
Satisfiability and relevance for queries over active documents
Serge Abiteboul 1 Pierre Bourhis 1 Bogdan Marinoiu 1
1 GEMO - Integration of data and knowledge distributed over the web
LRI - Laboratoire de Recherche en Informatique, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, CNRS - Centre National de la Recherche Scientifique : UMR8623
Abstract : Many Web applications are based on dynamic interactions between Web components exchanging flows of information. Such a situation arises for instance in mashup systems or when monitoring distributed autonomous systems. This is a challenging problem that has generated recently a lot of attention; see Web 2.0. For capturing interactions between Web components, we use active documents interacting with the rest of the world via streams of updates. Their input streams specify updates to the document (in the spirit of RSS feeds), whereas their output streams are defined by queries on the document. In most of the paper, the focus is on input streams where the updates are only insertions, although we do consider also deletions. We introduce and study two fundamental concepts in this setting, namely, satisfiability and relevance. Some fact is {\em satisfiable} for an active document and a query if it has a chance to be in the result of the query in some future state. Given an active document and a query, a call in the document is {\em relevant} if the data brought by this call has a chance to impact the answer to the query. We analyze the complexity of computing satisfiability in our core model (insertions only) and for extensions (e.g., with deletions). We also analyze the complexity of computing relevance in the core model.
Document type :
Conference papers
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/inria-00429645
Contributor : Pierre Bourhis Connect in order to contact the contributor
Submitted on : Tuesday, November 3, 2009 - 5:17:15 PM
Last modification on : Tuesday, October 25, 2022 - 4:17:37 PM
Long-term archiving on: : Tuesday, October 16, 2012 - 1:15:16 PM
File
pods37-abiteboul.pdf
Identifiers
  • HAL Id : inria-00429645, version 1
Citation
Serge Abiteboul, Pierre Bourhis, Bogdan Marinoiu. Satisfiability and relevance for queries over active documents. Proceedings of the Twenty-Eigth ACM SIGMOD-SIGACT-SIGART Symposium on Principles of Database Systems, PODS 2009,, Jun 2009, Providence, United States. ⟨inria-00429645⟩
Share
Metrics
Record views
518
Files downloads
185
