Higher-order matching modulo (super)developements. Applications to second-order matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
To perform higher-order matching, we need to decide the beta eta-equivalence on lambda-terms. The first way to do it is to use simply typed lambda-calculus and this is the usual framework where higher-order matching is performed. Another approach consists in deciding a restricted equivalence. This restricted equivalence can be based on finite developments or more interestingly on finite superdevelopments. We consider higher-order matching modulo (super)developments over untyped lambda-terms for which we propose terminating, sound and complete matching algorithms. This is in particular of interest since all second-order beta-matches are matches modulo superdevelopments. We further propose a restriction to second-order matching that gives exactly all second-order matches. We finally apply these results in the context of higher-order rewriting.
matching.pdf (314.68 Ko) Télécharger le fichier
inria-00429978 , version 1 (05-11-2009)
  • HAL Id : inria-00429978 , version 1
Germain Faure. Higher-order matching modulo (super)developements. Applications to second-order matching. [Research Report] 2009. ⟨inria-00429978⟩
71 Consultations
159 Téléchargements
