A general Church-Rosser theorem, 1978. ,
The Lambda-Calculus, its syntax and semantics. Studies in Logic and the 831 Foundation of Mathematics, 1984. ,
The complexity of unification, Thèse de doctorat, pp.1977-2006 ,
Matching ? A special case of unification? In Unification, pp.125-138, 1990. ,
The rewriting calculus - part II, Logic Journal of IGPL, vol.9, issue.3, pp.427-498, 1933. ,
DOI : 10.1093/jigpal/9.3.377
URL : https://hal.archives-ouvertes.fr/inria-00100532
Efficient second-order matching, Rewriting Tech- 839 niques and Applications -RTA'96, p.27, 1996. ,
DOI : 10.1007/3-540-61464-8_62
Natural semantics: specifications and proofs, p.842 ,
Higher Order Unification via Explicit Substitutions, Information and Computation, vol.157, issue.1-2, pp.183-235, 2000. ,
DOI : 10.1006/inco.1999.2837
URL : https://hal.archives-ouvertes.fr/hal-01199528
Higher-order matching for program transformation, p.846 ,
Third order matching is decidable, Annals of Pure and Applied Logic, vol.69, issue.2-3, pp.135-155, 1994. ,
DOI : 10.1016/0168-0072(94)90083-3
URL : http://doi.org/10.1016/0168-0072(94)90083-3
Higher-Order Unification and Matching, Handbook of Automated Reasoning, p.850 ,
DOI : 10.1016/B978-044450813-3/50018-7
Ellipsis and higher-order unification, Linguistics and Philosophy, vol.8, issue.1, pp.399-452, 1991. ,
DOI : 10.1007/BF00630923
URL : http://arxiv.org/abs/cmp-lg/9503008
Matching Modulo Superdevelopments Application to Second-Order Matching, 854 13th International Conference on Logic for Programming, Artificial Intelligence, and Reasoning 855 -LPAR'06, pp.60-74, 2006. ,
DOI : 10.1007/11916277_5
Structure et modèles de calcul de réécriture, Thèse de doctorat ,
The undecidability of the second order unification, Journal of Theoretical Computer Science, vol.859, issue.13 11, pp.225-230, 1981. ,
Proving and applying program transformations expressed with 861 second-order patterns, Acta Informatica, vol.11, issue.26, pp.17-27, 1978. ,
A mechanization of type theory, Proceedings of the 3rd 863 ,
Résolution d'´ equations dans les langages d'ordre 1, Thèse de doctorat 866 d'´ etat, p.27, 1975. ,
Solving equations in abstract algebras: A rule- 868 based survey of unification, Computational Logic -Essays in Honor of Alan Robinson, pp.869-257, 1991. ,
A new equational unification method: A generalization of martelli-montanari's 873 algorithm, pp.224-247, 1984. ,
Combinatory Reduction Systems, Mathematisch Centrum, Am- 875 sterdam, 1980. ,
Combinatory reduction systems: introduction and survey, Theoretical Computer Science, vol.121, issue.1-2, pp.279-308, 1993. ,
DOI : 10.1016/0304-3975(93)90091-7
URL : http://doi.org/10.1016/0304-3975(93)90091-7
Reductions Correctes et Optimales dans le Lambda-Calcul, 1978. ,
Higher Order ?? Matching is Undecidable, Logic Journal of IGPL, vol.11, issue.1, pp.51-881, 2003. ,
DOI : 10.1093/jigpal/11.1.51
URL : http://jigpal.oxfordjournals.org/cgi/content/short/11/1/51
Higher-order logic programming, Int. Conf. on Logic Programming, p.784, 1990. ,
DOI : 10.1007/3-540-16492-8_94
URL : https://hal.archives-ouvertes.fr/hal-00776197
A logic programming language with lambda-abstraction, function variables, and 885 simple unification, Journal of Logic and Computation, issue.2, p.14, 1991. ,
An Efficient Unification Algorithm, ACM Transactions on Programming Languages and Systems, vol.4, issue.2, p.887 ,
DOI : 10.1145/357162.357169
Higher-order rewrite systems and their confluence, Theoretical 889 Computer Science, p.32, 1998. ,
DOI : 10.1016/S0304-3975(97)00143-6
URL : http://doi.org/10.1016/s0304-3975(97)00143-6
Higher-order rewriting and equational reasoning, p.891 ,
Confluence for abstract and higher-order rewriting, p.32, 1994. ,
Decidability of fourth-order matching, Mathematical Structures in Computer Science, vol.10, issue.3 ,
DOI : 10.1017/S0960129500003108
URL : https://hal.archives-ouvertes.fr/hal-00527853
Logical Frameworks, Handbook of Automated Reasoning, pp.1063-1147, 2001. ,
DOI : 10.1016/B978-044450813-3/50019-9
Unification of higher-order patterns in linear time and space, Journal of Logic and Computation, vol.6, issue.3, p.14, 1996. ,
DOI : 10.1093/logcom/6.3.315
Higher-order unification revisited: Complete sets of transfor- 901 mations, JSCOMP: Journal of Symbolic Computation, vol.8, issue.15, p.27, 1989. ,
Extended matching with applications to program transformation, 1994. ,
Higher-order Matching for Program Transformation, Mag- 905 dalen College, p.3, 2001. ,
Decidability of higher-order matching, Logical Methods in Computer Science, vol.5, issue.3, p.14, 2009. ,
DOI : 10.2168/LMCS-5(3:2)2009
A survey of strategies in rule-based program transformation systems, Journal of 911 Symbolic Computation, 2005. ,
DOI : 10.1016/j.jsc.2004.12.011
Comparing combinatory reduction systems 913 and higher-order rewrite systems, Femke van Raamsdonk. Confluence and superdevelopments, pp.912-915, 1993. ,
