New interface
Reports (Research report)
CONSERVATION CORRECTION BY DUAL LEVEL SET
Anne-Cecile Lesage Alain Dervieux 1, *
* Corresponding author
1 TROPICS - Program transformations for scientific computing
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : When applied to the simulation of bi-fluid incompressible flow, the level set method does not ensure mass conservation of each fluid. Now this needs to be enforced. In this paper, we propose a complementary local mass conservation based on a weak formulation of the advection of the interface characteristic function. We first apply our method to the advection of a discontinuous concentration. Secondly, we couple our method with incompressible two-phase flow simulation and validate it on test cases where one fluid separates in disconnected parts (motion of two separated liquid volumes, water column falling on an obstacle).
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00430191
Contributor : Alain Dervieux Connect in order to contact the contributor
Submitted on : Friday, November 6, 2009 - 9:38:35 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:25 AM
Identifiers
  • HAL Id : inria-00430191, version 1
Collections
Citation
Anne-Cecile Lesage, Alain Dervieux. CONSERVATION CORRECTION BY DUAL LEVEL SET. [Research Report] 2009, pp.29. ⟨inria-00430191⟩
Share
Metrics
Record views
77
