Benchmarking the (1+1)-CMA-ES on the BBOB-2009 Noisy Testbed
We benchmark an independent-restart-(1+1)-CMA-ES on the BBOB-2009 noisy testbed. The (1+1)-CMA-ES is an adaptive stochastic algorithm for the optimization of objective functions defined on a continuous search space in a black-box scenario. The maximum number of function evaluations used here equals $10^{4}$ times the dimension of the search space. The algorithm could only solve $4$ functions with moderate noise in $5$-D and $2$ functions in $20$-D.
Analyse numérique [cs.NA]
