An efficient multi-algorithms sparse linear solver for GPUs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Stéphane Vialle
We present a new sparse linear solver for GPUs. It is designed to work with structured sparse matrices where all the non-zeros are on a few diagonals. Several iterative algorithms are implemented, both on CPU and GPU. The GPU code is designed to be fast yet simple to read and understand. It aims to be as accurate as possible, even on chips that do not support double-precision floating-point arithmetic. Several benchmarks show that GPU algorithms are much faster than their CPU counterpart while their accuracy is satisfying.
Fichier non déposé
inria-00430520 , version 1 (08-11-2009)
  • HAL Id : inria-00430520 , version 1
Thomas Jost, Sylvain Contassot-Vivier, Stéphane Vialle. An efficient multi-algorithms sparse linear solver for GPUs. ParCo2009, Frédéric Desprez, Sep 2009, Lyon, France. ⟨inria-00430520⟩
190 Consultations
0 Téléchargements
